3D Printable ESP32 Socket Case
Hey all, new to the smart home and home assistant rabbit hole, but I designed a 3d printable case to house my espresense devices that I’ve got placed around my house and thought it might be useful to
someone else.
It was designed with the following in mind:
I designed it in Fusion 360 fully parameterized, so if that means something to you and you’re interested in the project file to customize it for your needs I’d be happy to share.
This is very cool! Great work!
Great little project case. I’m using it for an IR blaster and would like to make the outer walls thicker to better hold the IR LED mounts. I’d love to get the Fusion file, if possible, please.
Sorry for the delayed response! I uploaded the .f3d file to the Thingiverse page, please let me know if you have any trouble with it.
This is fantastic! It’s exactly what I was envisioning when I started this google search. Great work!
Thanks for sharing.
I have some esp32s that are too wide so I made and shared a remix.
I really appreciate you providing the fusion file.
https://makerworld.com/en/models/1494185-espresence-socket-case-wide#profileId-1562277
This is great. I’m planning on buying a similar board. I cannot get the link to the power charger to work on Amazon. Do you have a model number? Also, will your case work if the board has the exposed pins on the bottom? Thanks again for making this!
