3d printed LED lamp D1 mini with PIR motion sensor
Fun bathroom lamp project.
Designed and 3d printed a funky LED night light lamp.
AM312 PIR motion sensor $2.50
2812b LED Strip with 27 LED nodes. $5.00
D1 min wifi micro controller. $5.00
5v 4amp power supply $5.00
Home assistant with ESPhome
On bathroom counter
Motion sensor turns it on with automation in node red.
Changes to a warning strobe just before light shuts off if no motion.
Shuts off after no motion for 10 minutes.
Home assistant automation:
alias: motion lamp rainbow on
description: ""
  - platform: state
    entity_id: binary_sensor.bathroom_motion2_2
    to: "on"
condition: []
  - service: light.turn_on
      brightness_pct: 100
      profile: default
      effect: Rainbow
      entity_id: light.bathroom_lamp
  - delay:
      hours: 0
      minutes: 9
      seconds: 45
      milliseconds: 0
  - if:
      - condition: device
        type: is_on
        device_id: 5f1902fd3b0047a466f4ae48d19b08fb
        domain: light
    then:
          brightness: 255
          effect: Strobe Effect With Custom Values
      - delay:
          hours: 0
I have moved most of my automations from Node Red to HA but here is my old flow.
Node red flow.
[{"id":"712cd2f1.82415c","type":"server-state-changed","z":"6dffafbd.e2808","name":"bathroom motion 10 minutes","server":"ceea5ac5.1b1658","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.bathroom_motion2_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"for":"10","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":360,"wires":[["40f2b740.5d1c68"],[]]},{"id":"40f2b740.5d1c68","type":"api-call-service","z":"6dffafbd.e2808","name":"turn lamp off","server":"ceea5ac5.1b1658","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.bathroom_lamp","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":350,"y":360,"wires":[[]]},{"id":"7d7ba951.47e3b8","type":"api-call-service","z":"6dffafbd.e2808","name":"strobe warning light will shut off in  15 seconds","server":"ceea5ac5.1b1658","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.bathroom_lamp","data":"{\"effect\": \"Strobe Effect With Custom Values\"}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":480,"y":200,"wires":[[]]},{"id":"16be9d5.1569563","type":"api-call-service","z":"6dffafbd.e2808","name":"rainbow effect bathroom","server":"ceea5ac5.1b1658","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.bathroom_lamp","data":"{\"effect\": \"My rainbow\"}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":370,"y":100,"wires":[[]]},{"id":"fab928d8.832d08","type":"server-state-changed","z":"6dffafbd.e2808","name":"bathroom motion off 9.75 min","server":"ceea5ac5.1b1658","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.bathroom_motion2_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":false,"for":"585","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":200,"wires":[["28e4533c.489d3c"],[]]},{"id":"28e4533c.489d3c","type":"api-current-state","z":"6dffafbd.e2808","name":"is light on?","server":"ceea5ac5.1b1658","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"light.bathroom_lamp","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":270,"y":260,"wires":[["7d7ba951.47e3b8"],[]]},{"id":"49acc7fd57364b02","type":"comment","z":"6dffafbd.e2808","name":"bathroom LED lamp motion activation","info":"","x":190,"y":40,"wires":[]},{"id":"074e3ecf681d8105","type":"comment","z":"6dffafbd.e2808","name":"strobe worning if in shower for almost 10 min.","info":"","x":170,"y":160,"wires":[]},{"id":"8bcf1562bca4777b","type":"comment","z":"6dffafbd.e2808","name":"shut off lamp if no motion for 10 min.","info":"","x":140,"y":320,"wires":[]},{"id":"ceea5ac5.1b1658","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
** updated ESPhome Code.**
esphome:
  platform: ESP8266
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "eb74a1eb04e91ad5896cd610fdcd1013"
wifi:
  ssid: "smarthome1"
  password: "password"
  ap:
    ssid: "Bathroom-Lamp Fallback Hotspot"
    password: "sLhtIU1ggkcF"
web_server:
  port: 80
captive_portal:
binary_sensor:
  - platform: gpio
    pin: D7
    device_class: motion
#light:
  #- platform: neopixelbus
   # id: bathroom_lamp
   # name: "bathroom lamp Light"
   # internal: True
  #  pin: D4
   # num_leds: 27
 #   variant: WS2812
  #  type: GRB
light:
    type: GRB
    variant: WS2812
    pin: D4
    num_leds: 27
 # - platform: fastled_clockless
 #   chipset: WS2812B
 #  pin: D4
 #   num_leds: 27
  #  rgb_order: GRB
  #  name: "FastLED WS2811 Light"
    effects:
      - addressable_rainbow:
          name: Rainbow Effect With Custom Values
          speed: 20
          width: 75
          speed: 5
          width: 30
      - addressable_color_wipe:
          name: Color Wipe Effect With Custom Values
          colors:
            - red: 100%
              green: 100%
              blue: 100%
              num_leds: 1
            - red: 0%
              green: 0%
              blue: 0%
              num_leds: 1
          add_led_interval: 100ms
          reverse: False
      - addressable_random_twinkle:
          name: Random Twinkle Effect With Custom Values
          twinkle_probability: 5%
          progress_interval: 32ms
      - flicker:
      - flicker:
          name: Flicker Effect With Custom Values
          alpha: 95%
          intensity: 1.5%
      - strobe:
      - strobe:
          name: Strobe Effect With Custom Values
          colors:
            - state: True
              brightness: 100%
              red: 100%
              green: 90%
              blue: 0%
              duration: 500ms
            - state: False
              duration: 250ms
            - state: True
              brightness: 100%
              red: 0%
              green: 100%
              blue: 0%
              duration: 500ms
      - addressable_scan:
      - addressable_scan:
          name: Scan Effect With Custom Values
          move_interval: 100ms
          scan_width: 1
      - addressable_twinkle:
          name: Twinkle Effect With Custom Values
          progress_interval: 4ms
      - addressable_fireworks:
          name: Fireworks Effect With Custom Values
          update_interval: 32ms
          spark_probability: 10%
          use_random_color: false
          fade_out_rate: 120
#Exposes control buttons
button:
  - platform: restart
    icon: mdi:power-cycle
time:
  - platform: sntp
################ diag ###################
    #Device UPTIME
  - platform: uptime
    update_interval: 60s
    #Device RSSI
  - platform: wifi_signal
    entity_category: "diagnostic"
3d printing info.
i only had white in PETG would have looked better in PLA.
lamp base1
tinker with tinkercad
[tinkercad ](tinker with tinkercad 3D design LED lamp_3 pieces | Tinkercad)
Thingiverse page.
thingiverse sti file and info
Hi, trying to do something similar. Will be able to share how you connected the led strips and the PIR to the wemos?
Fred
I have since changed motion automation from node red to to home assistant UI
description: ""
  - platform: state
    to: "on"
condition: []
      brightness_pct: 100
      profile: default
      effect: Rainbow
  - delay:
      hours: 0
      minutes: 9
      seconds: 45
      milliseconds: 0
  - if:
      - condition: device
        type: is_on
        domain: light
    then:
          brightness: 255
      - delay:
          hours: 0
          minutes: 0
          seconds: 15
          milliseconds: 0
      - type: turn_off
        domain: light
    else: []
mode: restart
Updated ESP home code and automation for HA automation off of Node Red.
