Hi everyone, here is my approach for the 3d printer automation:
Components used:
3D printer (Anet A8)
Octoprint on a Raspberry 1B
Smart plug (I am using an Ubiquitus mPower Pro, but a Wemo or equivalent will work)
I use telegram for notifications, but you can use any notification flavor you prefer.
You will have to setup octoprint on your raspberry first, it connects via usb to the printer and manages it directly. Octoprint official web
Then you have to add the configuration to your configuration yaml file as the octoprint documentation states:
octoprint:
host: your octoprint ip
api_key: your api key (you can get it on the octoprint options)
We want to add some sensors too:
- platform: octoprint
monitored_conditions:
- Current State
- Job Percentage
And here are the automation bits:
automation: #3d printer automations
- alias: Send me a notification when the print is above 50%
platform: numeric_state
entity_id: sensor.octoprint_job_percentage
above: 50
service: notify.Telegrambot
message: "Print is at 50%"
- alias: Send me a notification when the print is finished
platform: state
entity_id: sensor.octoprint_current_state
to: 'Operational'
- service: notify.Telegrambot
message: "Print has been finished"
- service: homeassistant.turn_on
entity_id: script.3dprint_off
As you can see, when the print has been finished, we start a script that works as follows:
> script:
3dprint_off:
alias: ¨Turn off 3d printer after 2 minutes¨
sequence:
- delay:
minutes: 2
- service: switch.turn_off
entity_id: switch.3dprinter
Hope that this helps out somebody, as it comes pretty handy. You can make some other related automations, that for example turns off the printer if it reports an error on the printing and notify you, etc…
Just let me know if you need any detail about it.
One detail: Octoprint component needs the 3dprinter to be on when home assistant is restarted or the component will fail
Nice! I have just picked up an Anet A8 3D Printer!
I was tempted to look into Octoprint to see if it’s worthwhile setting up. The RPI I have is a Rev1, and whilst supported cannot imagine it would be up to much.
Can I ask what settings you used to connect the printer in Octoprint? I didn’t have any luck with everything I tried. Latest version of octoprint running on a Raspberry pi model B.
Sure, you have to select 115200 as baudrate and in serial port you will have to choose /dev/ttyUSBx (if your octoprint is not detecting your usb you can try rebooting octoprint.
Thanks for that. Will give it a go shortly but looks pretty similar to the settings I chose. I suppose the USB cable they supplied could be a dud. Are you using the stock firmware on the anet board?
I did get it working fine with RPI Rev1. I just purchased a RPI Zero W (wireless version) to use that instead, but the Octopi image does not support it.
I am going to try manually building using the latest Raspbian Lite image.
What is a shame (and also have the same issue with the Zoneminder component) is that it requires Octopi to be accessible when HASS starts up. If you have it switched off (as I do when not using it) then restarting HASS causes it to freak out
Wonder if there’s anything that can be done to solve this - I guess it’s also some limitation on the HASS back end too?
@mitsumaui – If you want a quick and easy setup for OctoPrint use OctoPi. That’s what I use for my RaspberryPi 2 connected to my Monoprice select mini.
Yep! I had Octopi running on a Pi Zero 1, and an RPI 1 without issue, but at the moment it does not support the Pi Zero W.
I have opened an ‘issue’ with OctPi on GitHub and they are looking to roll the latest Raspbian into their nightlies soon so should be able to test with that at some point. But hence the hand build for the moment!
