Hey, can you share some more details about the way you’re implementing this? Are you writing a plugin for Q-SYS to communicate with the Home Assistant Websocket API?
Hi Timothy,
Exactly, i’ve wrote a plugin in Lua, my issue is when i’m dimming a light, the eventhandler of the knob send too many request to hassio.
I’m not sure how to resolve this.
I’ve actually got a Core 110f on hand I can test with. If you’re willing to send me a copy of your q-sys design, I can load it up and take a look at it.
Yeah, I work in systems integration, control systems, and show control systems in my day job. We’re QSC dealers and use them extensively for theater audio and touchscreen UI interfaces to interact with our in-house control software. My secret desire is to be able to justify buying a core for my house, but I don’t see that becoming a reality anytime soon
Are you doing this integration for a professional project or for your personal system?
Professional QSC programmer, based in Quebec Canada.
French Canadian, that’s why my english aren’t perfect…
I’m the owner of a small company, basically DSP programation, but 80% of my business are Q-SYS !
And I had to buy a 110f to have the support of QSC to be on their website.
My plugin are available on the QSYS sharing group on Facebook, you’ll want to follow this group, a lot of goods stuffs here.
Oh, great! Don’t worry about your english - I’m American so mine’s not great either
I haven’t used Facebook much for a past few years, but just joined the QSC QSYS Programming Sharing Group. I’ll check it out from there, though.
Hope everyone is still around as this is an old post.
Did anyone ever have luck with this integration?
We are currently looking at implementing HA into a school project for Lighting, Air Con Control and Energy Management.
There was a question if they could integrate HA into Q-SYS or vice Verca. Would be really good to know if someone has achieved this as this is a bit above my scope as I have never used QSYS before
I put it on the main page but here is what i modited from my setup with your data.
note you will need to change your pknight to transmite, ( Artnet → DMX)
also note my light only run in “8bit” mode but yours might be ok with 16bit.
light:
- platform: artnet_led
host: 192.168.0.100 # IP of PKnight node
max_fps: 25 # Max 40 per second
refresh_every: 0 # Resend values if no fades are running every x seconds, 0 disables automatic refresh
node_type: artnet-direct # Which protocol to use
universes: # Support for multiple universes
0: # Nr of Universe (see configuration of your Art-Net Node)
send_partial_universe: True # Only send the universe which contains data
output_correction: quadratic # optional: output correction for the whole universe, will be used as default if nothing is set for the channel
devices:
# Dimmer
- channel: 1
type: rgb
transition: 1
channel_size: 16bit
channel_setup: rgb # Auto-calculated white channel
well! I think it was a stupid thing in that the light seemed to need to have been set to d001 then turned off and on again while left on that setting‽ I think I’d set it to that then cycled through other things, but not restarted it…
I can now turn it on and off - but it’s currently ignoring requests to change colour, it’s just on max all the time. I’ll play with the channel setup.
Progress!
edit: Some of the channel setup things in the readme of the repo definitely aren’t right
aa, it works! It just didn’t work with the colour buttons on the card - if I click on the lightbulb and go to the hue picker, it works. Just need to work out how to do it all programmatically and we’re in gravy. Thanks @SquirrelRange
Final config:
# Dimmer
- channel: 1
type: rgbw
transition: 1
channel_size: 8bit
channel_setup:
- r
- g
- b
- W
