I’ve recently purchased a 3rd Reality Water Leak Sensor, and it appears to work, but I can’t seem to get it to turn off a switch (attached to a sump pump) when it stops sensing moisture.
Turning the pump on works almost instantly, and is exactly what I need, but when the moisture drops below the sensor I need it to turn off.
Here’s my two code snippets - I’m hoping someone can help me out.
I’m using latest HAOS/HA in VirtualBox and everything else works fine (presence sensor, smart plugs, etc.). I used the GUI to create the automation.
Working Code:
alias: Turn Window Sump Pump ON
description:
triggers:
- type: moist
device_id: 0466edee3436f407c58e1013a182e39b
entity_id: 2e32e1fae4de439fb71a641f6e650e41
domain: binary_sensor
trigger: device
conditions: []
actions:
- action: switch.turn_on
entity_id:
- switch.new_outdoor_smart_plug_plug_2
data: {}
- data:
message: Sump Pump Turned ON
title: Sump Pump Off Notification
action: notify.notify
mode: single
Broken Code:
alias: Turn Window Sump Pump Off
description:
triggers:
- type: not_moist
trigger: device
conditions: []
actions:
- target:
entity_id: switch.new_outdoor_smart_plug_plug_2
action: switch.turn_off
data: {}
- data:
message: Sump Pump Turned OFF
mode: single
