4 buttons for 4 automations in one?
I can’t get this to work. I am sure it’s very simple but i get stuck trying to get to get it working.
I have a scene switcher with 4 buttons, which i want to use the upper left to open left garage door and bottom left to close the left garage door and so on.
Am i right that this needs to be done with choose?
I can easily add the 4 triggers, but can not find those triggers in the chose conditions.
description: ""
mode: single
  - platform: device
    domain: mqtt
    device_id: 1a7bc0f10179a938b2325fec11a3be7a
    type: action
    subtype: 1_single
    discovery_id: 0x847127fffee7aeb3 action_1_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 2_single
    discovery_id: 0x847127fffee7aeb3 action_2_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 3_single
    discovery_id: 0x847127fffee7aeb3 action_3_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 4_single
    discovery_id: 0x847127fffee7aeb3 action_4_single
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: sensor.garage_doors_switch_front_door_action
            state: ""
        sequence: []
Any help here or a pointer in the right direction would be appreciated!
Thanks!
Try something like this:
  - platform: mqtt
    topic: zigbee2mqtt/<friendly_name>/action
condition: '{{ trigger.payload in ["1_single", "2_single", "3_single", "4_single"] }}'
  - choose:
      - conditions: '{{ trigger.payload == "1_single" }}'
        sequence:
          - service: ...
      - conditions: '{{ trigger.payload == "2_single" }}'
        sequence:
          - service: ...
Does this look right?
alias: Garage test
description: ""
  - platform: mqtt
    topic: zigbee2mqtt/<Garage_doors_switch_front_door>/action
condition:
  - "{{ trigger.payload in [\"1_single\", \"2_single\", \"3_single\", \"4_single\"] }}"
  - choose:
      - conditions: "{{ trigger.payload == \"1_single\" }}"
        sequence:
          - service: cover.open_cover
            data: {}
              device_id: 49f6a52ca182735e3988a12bf2b21cd6
mode: single
i just added the 1st button for the sake of the test, but nothing happens.
If you are using zigbee2mqtt you should use the device/entities, not use mqtt directly.
Remove both <> at, then it should work.
Thanks to both! Manage to make it work. Used device for trigger and the payload condition for choose action.
However, is this possible to do through the gui? I dont get why it finds the buttons as triggers, but not in the chose conditions.
