substitutions:
light_id: "wiz_rgbw_tunable_xxxxxx"
esphome:
friendly_name: light-remote
rp2040:
board: rpipicow
framework:
# Required until https://github.com/platformio/platform-raspberrypi/pull/36 is merged
platform_version: https://github.com/maxgerhardt/platform-raspberrypi.git
# Enable logging
logger:
level: debug
# Enable Home Assistant API
api:
encryption:
key: "hash"
ota:
password: "hash"
wifi:
ssid: !secret wifi_ssid
# Enable fallback hotspot in case wifi connection fails
ap:
ssid: "light-remote Fallback Hotspot"
password: "hash"
use_address: static
switch:
- platform: restart
light:
- platform: status_led
pin: GPIO17
binary_sensor:
#touch_1
- platform: gpio
pin:
number: GPIO18
mode:
input: true
pullup: false
internal: True
on_press:
then:
- light.turn_on: status_blue
- script.execute: toggle_light
on_release:
then:
- light.turn_off: status_blue
#touch_2
- platform: gpio
pin:
number: GPIO21
mode:
input: true
pullup: false
internal: True
on_press:
then:
- script.execute: select_scene
on_release:
then:
#touch_3
- platform: gpio
pin:
number: GPIO20
mode:
input: true
pullup: false
internal: True
on_press:
then:
- script.execute: increase_brightness
on_release:
then:
#touch_4
- platform: gpio
pin:
number: GPIO19
mode:
input: true
pullup: false
internal: True
on_press:
then:
- script.execute: decrease_brightness
on_release:
then:
select:
optimistic: true
options:
- "Relax"
- "Focus"
- "Warm White"
- "Cool white"
initial_option: "Warm White"
on_value:
then:
- homeassistant.service:
service: light.turn_on
entity_id: light.${light_id}
data_template:
effect: !lambda return x.c_str();
- platform: homeassistant
attribute: brightness
filters:
- debounce: 5s
on_value:
then:
- number.set:
value: !lambda return x;
number:
optimistic: true
min_value: 0
max_value: 255
step: 25
on_value:
then:
data_template:
brightness: !lambda return x;
script:
- id: toggle_light
then:
service: light.toggle
- id: select_scene
then:
- select.next:
- id: increase_brightness
then:
- while:
condition:
and:
- binary_sensor.is_on: touch3
- number.in_range:
below: 254
then:
- number.increment:
cycle: False
- delay: 200ms
- id: decrease_brightness
then:
- while:
condition:
and:
- binary_sensor.is_on: touch4
- number.in_range:
above: 26
then:
- number.decrement:
cycle: False
- delay: 200ms
