HI
I living in EU and I’m looking for 4 gang switch which is two 2 gang switch under each other. I can find a 4 gang switch but those only consume one space, so I will have there a hole which I won’t be able to cover, and I can’t fin two 2 gangs one too, because it has two big sides borders (top and bottom). Did anyone face this issue?
The same issue with the 2 gang 2-way switch, but here is two single switches under each other which are 2-way switches. (I guess the 2-way functionality can be simply done with a two simple switch from software right?)
