Title says it all. I have 4 Miflora sensors. Reporting works perfectly with temperature, humidity, conductivity. On all four though, there seems to be no brightness reported. Here’s what I see in the dashboard:
Here’s what I have in configuration.yaml (minus the mac addresses which have been X’d out):
- platform: miflora
mac: "XX:XX:XX:XX:XX:X"
monitored_conditions:
- moisture
- temperature
- conductivity
- light
- platform: miflora
- moisture
- temperature
- light
- conductivity
- battery
- platform: miflora
- moisture
- temperature
- light
- conductivity
- battery
plant:
Spiderplant:
sensors:
moisture: sensor.spider_plant_moisture
battery: sensor.spider_plant_conductivity
temperature: sensor.spider_plant_temperature
conductivity: sensor.spider_plant_conductivity
brightness: sensor.spider_plant_brightness
min_moisture: 15
max_moisture: 60
min_battery: 5
min_temperature: 10
max_temperature: 32
min_conductivity: 200
max_conductivity: 1300
min_brightness: 500
max_brightness: 30000
check_days: 3
Aloe:
sensors:
moisture: sensor.aloe_plant_moisture
battery: sensor.aloe_plant_conductivity
temperature: sensor.aloe_plant_temperature
conductivity: sensor.aloe_plant_conductivity
brightness: sensor.aloe_plant_brightness
min_moisture: 7
max_moisture: 50
min_battery: 5
min_temperature: 8
max_temperature: 35
min_conductivity: 300
max_conductivity: 1000
min_brightness: 3000
max_brightness: 70000
check_days: 3
Citrus plant:
sensors:
moisture: sensor.citrus_tree_moisture
battery: sensor.citrus_tree_conductivity
temperature: sensor.citrus_tree_temperature
conductivity: sensor.citrus_tree_conductivity
brightness: sensor.citrus_tree_brightness
min_moisture: 15
max_moisture: 60
min_battery: 5
min_temperature: 16
max_temperature: 32
min_conductivity: 350
max_conductivity: 2000
min_brightness: 2500
check_days: 3
Configuration checker reports everything as OK. Yes, I know I need to give them fertilizer! Any other ideas, gratefully appreciated!
