400: Bad Request error
I installed Home Assistant using Docker and its behind Nginx Proxy Manager, when I access it I get error like:
400: Bad Request
I read that I have to change configuration.yaml (add use_x_forwarded_for) so my configuration looks like:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 192.168.1.80 # Add the IP address of the proxy server
    - server.local
I restarted container and nothing happened error is still there, what I am doing wrong?
Solved: I had to set docker container’s IP address.
