Hi, new to home assistant, automation and linux based systems in general.
I am trying to setup my reolink doorbell in frigate. I’ve got everything installed but can’t get a yaml working that lets me connect to the stream. I keep getting the same 401 auth error.
I know this is typically incorrect credentials, but I have double (triple, no quadruple!) checked the details, even creating a new user just for this login and it keeps erroring out. I’ve read through HA, Frigate, go2rtc documentation, I’ve been sitting with ChatGPT for several hours at this point trying all the different settings, logs, menus etc etc I’ve tried writing yamls with and without go2rtc, I’ve tried other configs/settings that have been suggested in other threads and nothing has worked - always the same 401 error. I’ve restarted the camera and HA OS several times throughout all of this testing and tweaking.
I can access the camera fine using the Reolink integration in HA, or by probing the IP address directly via web browser.
Here is one of the super basic config files I am trying to run. I know 1000000% the credentials are fine. I’ll try and add log files too
mqtt:
enabled: false
cameras:
reolink:
enabled: true
ffmpeg:
inputs:
- path: rtsp://username:[email protected]:554/rtsp
roles:
- detect
detect:
enabled: false
version: 0.14
2024-12-04 01:06:12.913881968 [2024-12-04 01:06:12] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:06:12.914373014 [2024-12-04 01:06:12] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:06:12.914640889 [2024-12-04 01:06:12] ffmpeg.reolink.detect ERROR : [tcp @ 0x55a07852d2c0] Connection to tcp://10.0.0.28:554?timeout=5000000 failed: Connection timed out
2024-12-04 01:06:12.915075707 [2024-12-04 01:06:12] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Connection timed out
2024-12-04 01:06:13.117576319 [2024-12-04 01:06:13] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:06:13.117870320 [2024-12-04 01:06:13] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:06:18.564126613 127.0.0.1 - - [04/Dec/2024:01:06:18 +0000] "" 400 0 "-" "-" "-"
2024-12-04 01:06:22.931467631 [2024-12-04 01:06:22] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:06:22.931919759 [2024-12-04 01:06:22] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:06:22.932452967 [2024-12-04 01:06:22] ffmpeg.reolink.detect ERROR : [rtsp @ 0x5637a262bfc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:06:22.932698095 [2024-12-04 01:06:22] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:06:23.211939799 [2024-12-04 01:06:23] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:06:23.212220029 [2024-12-04 01:06:23] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:06:32.950496296 [2024-12-04 01:06:32] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:06:32.950850278 [2024-12-04 01:06:32] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:06:32.951341766 [2024-12-04 01:06:32] ffmpeg.reolink.detect ERROR : [rtsp @ 0x55c71dcbafc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:06:32.951689093 [2024-12-04 01:06:32] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:06:33.338766418 [2024-12-04 01:06:33] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:06:33.338982582 [2024-12-04 01:06:33] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:06:37.641117685 172.30.32.2 - - [04/Dec/2024:01:06:37 +0000] "GET // HTTP/1.1" 200 2721 "http://homeassistant.local:8123/ccab4aaf_frigate" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:06:37.963578017 172.30.32.2 - - [04/Dec/2024:01:06:37 +0000] "GET /api/config HTTP/1.1" 200 7629 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:06:37.966035703 172.30.32.2 - - [04/Dec/2024:01:06:37 +0000] "GET /api/profile HTTP/1.1" 200 18 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:06:37.990571016 172.30.32.2 - - [04/Dec/2024:01:06:37 +0000] "GET /api/review?limit=10&severity=alert HTTP/1.1" 200 3 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:06:38.035277834 172.30.32.2 - - [04/Dec/2024:01:06:38 +0000] "GET /api/reolink/latest.webp?h=360&cache=1733274398599 HTTP/1.1" 200 3654 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:06:38.052059806 172.30.32.2 - - [04/Dec/2024:01:06:38 +0000] "GET /api/reolink/latest.webp?h=270&cache=1733274398599 HTTP/1.1" 200 2466 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:06:40.709293783 172.30.32.2 - - [04/Dec/2024:01:06:40 +0000] "GET /ws HTTP/1.1" 101 98 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:06:42.967879808 [2024-12-04 01:06:42] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:06:42.968233315 [2024-12-04 01:06:42] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:06:42.968591291 [2024-12-04 01:06:42] ffmpeg.reolink.detect ERROR : [rtsp @ 0x5641c2208fc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:06:42.969017073 [2024-12-04 01:06:42] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:06:43.330144848 [2024-12-04 01:06:43] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:06:43.330404858 [2024-12-04 01:06:43] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:06:52.983974967 [2024-12-04 01:06:52] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:06:52.984274719 [2024-12-04 01:06:52] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:06:52.984574335 [2024-12-04 01:06:52] ffmpeg.reolink.detect ERROR : [rtsp @ 0x5615ba05cfc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:06:52.984579542 [2024-12-04 01:06:52] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:06:53.287092621 [2024-12-04 01:06:53] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:06:53.287308367 [2024-12-04 01:06:53] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:07:02.995748700 [2024-12-04 01:07:02] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:07:02.996137758 [2024-12-04 01:07:02] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:07:02.996576610 [2024-12-04 01:07:02] ffmpeg.reolink.detect ERROR : [rtsp @ 0x55d712ec4fc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:07:02.996947155 [2024-12-04 01:07:02] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:07:03.338523244 [2024-12-04 01:07:03] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:07:03.338805409 [2024-12-04 01:07:03] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:07:08.835624345 172.30.32.2 - - [04/Dec/2024:01:07:08 +0000] "GET // HTTP/1.1" 200 2721 "http://homeassistant.local:8123/ccab4aaf_frigate" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:07:09.192969258 172.30.32.2 - - [04/Dec/2024:01:07:09 +0000] "GET /api/config HTTP/1.1" 200 7629 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:07:09.201094839 172.30.32.2 - - [04/Dec/2024:01:07:09 +0000] "GET /api/profile HTTP/1.1" 200 18 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:07:09.303985040 172.30.32.2 - - [04/Dec/2024:01:07:09 +0000] "GET /api/review?limit=10&severity=alert HTTP/1.1" 200 3 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:07:09.334023824 172.30.32.2 - - [04/Dec/2024:01:07:09 +0000] "GET /api/reolink/latest.webp?h=360&cache=1733274429885 HTTP/1.1" 200 3654 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:07:09.334098333 172.30.32.2 - - [04/Dec/2024:01:07:09 +0000] "GET /api/reolink/latest.webp?h=270&cache=1733274429885 HTTP/1.1" 200 2466 "http://homeassistant.local:8123/api/hassio_ingress/bVSzuFv9cAF0-c7DwiSNUkNJpvfICFQdqQSAu4B-3ak//" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:07:13.013193019 [2024-12-04 01:07:13] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:07:13.013580859 [2024-12-04 01:07:13] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:07:13.013998668 [2024-12-04 01:07:13] ffmpeg.reolink.detect ERROR : [rtsp @ 0x556ff4e61fc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:07:13.014338653 [2024-12-04 01:07:13] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:07:13.136719087 [2024-12-04 01:07:13] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:07:13.137010188 [2024-12-04 01:07:13] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:07:18.588418591 127.0.0.1 - - [04/Dec/2024:01:07:18 +0000] "" 400 0 "-" "-" "-"
2024-12-04 01:07:23.030583697 [2024-12-04 01:07:23] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:07:23.030929390 [2024-12-04 01:07:23] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:07:23.031369775 [2024-12-04 01:07:23] ffmpeg.reolink.detect ERROR : [rtsp @ 0x5643b6d3afc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:07:23.031689920 [2024-12-04 01:07:23] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:07:23.374033985 [2024-12-04 01:07:23] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:07:23.374310301 [2024-12-04 01:07:23] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:07:33.047815818 [2024-12-04 01:07:33] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:07:33.048157838 [2024-12-04 01:07:33] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:07:33.048625847 [2024-12-04 01:07:33] ffmpeg.reolink.detect ERROR : [rtsp @ 0x5589e4e16fc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:07:33.048973520 [2024-12-04 01:07:33] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:07:33.377584068 [2024-12-04 01:07:33] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:07:33.377908050 [2024-12-04 01:07:33] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:07:43.065399786 [2024-12-04 01:07:43] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:07:43.065795735 [2024-12-04 01:07:43] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:07:43.066245547 [2024-12-04 01:07:43] ffmpeg.reolink.detect ERROR : [rtsp @ 0x560e4332cfc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:07:43.066437688 [2024-12-04 01:07:43] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:07:43.497418296 [2024-12-04 01:07:43] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:07:43.497688288 [2024-12-04 01:07:43] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:07:53.082170706 [2024-12-04 01:07:53] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:07:53.082571060 [2024-12-04 01:07:53] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:07:53.083171974 [2024-12-04 01:07:53] ffmpeg.reolink.detect ERROR : [rtsp @ 0x558ca7d25fc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:07:53.083183165 [2024-12-04 01:07:53] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:07:53.397541779 [2024-12-04 01:07:53] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:07:53.397810093 [2024-12-04 01:07:53] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:08:03.098025019 [2024-12-04 01:08:03] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:08:03.098415746 [2024-12-04 01:08:03] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:08:03.098776373 [2024-12-04 01:08:03] ffmpeg.reolink.detect ERROR : [rtsp @ 0x55e519127fc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:08:03.099143385 [2024-12-04 01:08:03] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:08:03.411227896 [2024-12-04 01:08:03] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:08:03.411532137 [2024-12-04 01:08:03] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:08:04.082951870 172.30.32.2 - - [04/Dec/2024:01:08:04 +0000] "GET /ws HTTP/1.1" 101 6914 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0" "10.0.0.10, 172.30.32.1"
2024-12-04 01:08:13.115627890 [2024-12-04 01:08:13] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:08:13.115975773 [2024-12-04 01:08:13] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:08:13.116485653 [2024-12-04 01:08:13] ffmpeg.reolink.detect ERROR : [rtsp @ 0x55560bf7bfc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:08:13.116773469 [2024-12-04 01:08:13] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:08:13.236366954 [2024-12-04 01:08:13] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:08:13.236581252 [2024-12-04 01:08:13] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
2024-12-04 01:08:18.612976317 127.0.0.1 - - [04/Dec/2024:01:08:18 +0000] "" 400 0 "-" "-" "-"
2024-12-04 01:08:23.133329021 [2024-12-04 01:08:23] watchdog.reolink ERROR : Ffmpeg process crashed unexpectedly for reolink.
2024-12-04 01:08:23.143189128 [2024-12-04 01:08:23] watchdog.reolink ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2024-12-04 01:08:23.143546810 [2024-12-04 01:08:23] ffmpeg.reolink.detect ERROR : [rtsp @ 0x56219463bfc0] method DESCRIBE failed: 401 Unauthorized
2024-12-04 01:08:23.143769570 [2024-12-04 01:08:23] ffmpeg.reolink.detect ERROR : rtsp:/10.0.0.28:554/rtsp: Server returned 401 Unauthorized (authorization failed)
2024-12-04 01:08:23.537555232 [2024-12-04 01:08:23] frigate.video ERROR : reolink: Unable to read frames from ffmpeg process.
2024-12-04 01:08:23.537789260 [2024-12-04 01:08:23] frigate.video ERROR : reolink: ffmpeg process is not running. exiting capture thread...
Please help! What am I missing?
