Not sure what happened but as of yesterday I am unable to access the web interface of Home Assistant. Everything works (automations, notifications, etc.) but when trying to connect I keep getting a 403: forbidden error. This message is only happening while on local wifi, if I disconnect from wifi I am able to access the frontend. Running Hass.IO with duckdns on version .73b5 on a pi 3.
Thought it might have been the below in http component but removing didn’t do anything.
I’ve had a problem with this continuously happening when using the iOS app, and been trying to get to the bottom of it. Check out this issue on Github if you’d like to follow the discussion on there.
