I just bought these Nexa Remote Switches https://www.clasohlson.com/uk/Nexa-Remote-Switch-Set-3-pack/18-2650. The switches are self-learning and can be paired with up to three different remotes.
As I understand, it’s possible to pair a switch by sending a code using the rpi_rf platform in Home Assistant. Problem is that the protocol for these switches is 32-bit and not 24-bit that is common for 433 MHz RF.
How do I set these up using Home Assisant and hass.io? What’s format should the codes have?
