433MHz Alarm system, Sonoff RF bridge + KERUI D025 + Alarmo
Introduction:
  • An alarm panel controlling 6 window/door alarm sensors (433MHz) using a sonoff RF bridge R2.2 (with or without esphome). Sends custom notifications and is reliable.
  • KERUI D025 sensors that sends three unique signals: open, close, and low battery
Steps overview
OPTION 1: using original firmware and ewelink app
  1. Set up RF bridge with ewelink app
  2. Add each signal of the each sensor as a separate “remote” (ewelink app, limit 16 devices: 4 sensors x 3 signals each)
  3. Link RF bridge to HA (SonoffLAN integration)
  4. Combine the open/close signals into one binary sensor (YAML)
  5. set up Alarmo
OPTION 2: using esphome firmware (no portisch)
  1. Flash RF bridge with esphome
  2. Ask home assistant to monitor RF events broadcasted by the bridge
  3. Combine open/close events into one binary sensor
  4. Set up Alarmo
OPTION 1:Original firmware
  2. Ewelink app: add each signal of the each sensor as a separate “remote”. You have to push the learn button
  • Ewelink doesn’t let you set up a door sensor with unique signals for open/close/low battery, so you have to set them up as separate devices. This will eat storage space on the bridge because the bridge is limited to limit 16 devices: 4 sensors x 3 signals each or 8 sensors x 2 signals each (if you don’t care about low battery)
  1. Link RF bridge to HA (SonoffLAN integration): install it from HACS, you have to enter your ewelink credentials for the integration to get the encryption keys for the bridge.
  • Although the integration is local (I checked with wireshark), if internet access is banned for the bridge, the timestamp attribute for open/close events will be missing and the bridge will not report the state of sensors
  1. Combine the open/close signals into one binary sensor (YAML):
    In configuration.yaml add the following, repeat for each sensor:
sonoff:
  rfbridge:
    office_open:  # button/alarm name in eWeLink application (open signal)
      name: Office window sensor  # optional, you can change sensor name
      device_class: window  # e.g. door, window
      timeout: 0  # disable auto close timeout
      payload_off: office_close # button/alarm name in eWeLink application (close signal)
    kitchen_open:  # button/alarm name in eWeLink application (open signal)
      name: Kitchen window sensor  # optional, you can change sensor name
      payload_off: kitchen_close # button/alarm name in eWeLink application (close signal)
For whaver reason, the bridge goes unavailable 3 times a day for 5 seconds, no detection happens in that state. Thats why I recommend option 2. I tried both for 3 months
OPTION 2: using esphome firmware (no portisch/no direct hack mod)
Direct hack allows esphome to control the RF chip directly. Not needed for D025 sensors.
1) Flash RF bridge with esphome (using this guide)
  • Use the J2 pins to flash (its not mentioned in the guide)
  • I had success flashing with bridge powered by its own USB port. I was using a 8266 nodemcu as an FTDI.
  • I flashed using ESPhome addon to make the firmware.bin and used esp web tools to flash (windows PC)
Here’s my esphome yaml:
esphome:
  friendly_name: Sonoff RF Bridge
esp8266:
  board: esp01_1m
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "use your own key mine was generated automatically with esphome"
  services:
    - service: send_rf_code
      variables:
        sync: int
        low: int
        high: int
        code: int
      then:
        - rf_bridge.send_code:
            sync: !lambda 'return sync;'
            low: !lambda 'return low;'
            high: !lambda 'return high;'
            code: !lambda 'return code;'
    - service: learn
      then:
        - rf_bridge.learn
rf_bridge:
  on_code_received:
    then:
      - homeassistant.event: # report RF signal in Hexadecimal
          event: esphome.rf_code_received
            sync: !lambda 'return format_hex(data.sync);'
            low: !lambda 'return format_hex(data.low);'
            high: !lambda 'return format_hex(data.high);'
            code: !lambda 'return format_hex(data.code);'
      - homeassistant.event: #report RF signal in decimal. decimal values worked better for me
            sync: !lambda 'return int(data.sync);'
            low: !lambda 'return int(data.low);'
            high: !lambda 'return int(data.high);'
            code: !lambda 'return int(data.code);'
ota:
 - platform: esphome
   password: "se your own key mine was generated automatically with esphome"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Sonoff-Rf-Bridge"
    password: "xxxxxxxx"
captive_portal:
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 19200
button:
  # Restart the ESP
  - platform: restart
# Sensors for ESP version and WIFI information
text_sensor:
  # ESPHome version
  - platform: version
    hide_timestamp: true
  # IP address and connected SSID
  - platform: wifi_info
    ip_address:
      icon: mdi:wifi
    ssid:
      icon: mdi:wifi-strength-2
  # WiFi signal
  - platform: wifi_signal
    update_interval: 120s
  - platform: uptime
    name: Sonoff RF Bridge Uptime
binary_sensor:
  - platform: status
    name: Sonoff RF Bridge Status
light:
  - platform: status_led
    pin:
      number: GPIO13
      inverted: true
#I have an LED strip with a remote, this switch template turns it on an off.
switch:
    optimistic: true
    turn_on_action:
          sync: 24182
          low: 758
          high: 2396
          code: 49921
    turn_off_action:
          sync: 22466
          low: 768
          high: 2386
          code: 49923
Instead of the bridge learning and storing each signal, we’ll just have home assistant monitor the RF signals:
In HASS, Go to Developer tools>Events> start listening.
Write down the signal events for each sensor and each signal (open/close/low battery).
  • For the D025 sensors, the sync/low/high keeps changing but the “code” value is always the same. I only use the “code” value for automations/templating.
  • I also found out that low battery code = open signal code + 1 (decimal values)
3) Combine open/close events into one binary sensor
In Home assistant configuration.yaml
template:
####Office window#####
- trigger:
    - platform: event
      event_type: esphome.rf_code_received
      event_data: #replace with your own
        device_id: c893ffef7e1816adeb244f4e138f7840
        code: "12345678"
    - platform: event
        code: "12345678"
  binary_sensor:
    - name: Office window
      state: "{{ trigger.id }}"
Integration with Alarmo
Alarmo has a lot of options. Install it via HACS and read the docs but I want to share a custom scripts for mobile notifications:
Notify phone when triggered. Alarmo>Actions>New Notification
service: notify.mobile_app_poco_f3
  message: Alarm triggered! {{open_sensors|format=short}}.
  title: Alarmo
    ttl: 0
    importance: max
    channel: alarm_stream
    notification_icon: mdi:shield-home
    color: red
    actions:
      - action: ALARMO_DISARM
        title: Disarm
      - action: URI
        title: Call 911
        uri: >-
          intent://scan/#Intent;scheme=tel:911;action=android.intent.action.DIAL;end
Excellent guide!
Thanks very much for sharing. Very useful.
