Started with the Xiaomi Gateway and the door/motion sensors. With my flows in Node it would sometimes send a random On/Off code. I got around that by adding a trigger node in the beginning of the flow. So the door had to be open for more than 50 milliseconds before passing the message. That worked fine for stopping the false alarms. Chalked it up to maybe some sort of disconnect/reconnect issue with the Gateway.
Then I added a Sonoff Rf bridge Flashed with Tasmota and some cheap 2 code door sensors. Those also sent the ghost codes, so I ruled out it being a Xiaomi specific issue. THEN I got a Xiaomi cube… The states work in a much different way, so my previous work-around wont cut it this time. It also gets a few false alarms a day. Figure I might try and get to the bottom of why…
I dont know where to begin as far as if this would be seen in a log somewhere.
Still trying to figure out how to post pics. So I’ll get the flow pic up if that could help…
