I found a RF 433 MHz switch that i like to install at home, but I want it to be controled by HA. I never used RF before. So what are my options? What I need to have in order for it to work?
I looked at google and found this device on AliExpress:
It would be helpful to know the exact switch you intend to control, from there you can search if there is a library already published somewhere - easiest and ideally if it’s already in RFLink. If it is, once set up it should start discovering devices automatically.
Otherwise I know there are docker repositories that would take whatever you receiver/transmitter you choose and expose devices over MQTT. I don’t have experience on that since I like to run bare metal and not multiple dockers.
