Hi, I am trying to configure in HASS some 433Mhz door sensors. They do send two diferent codes for ON and OFF, I do not know how to configure it, like below is wrong
this is what I receive when open and close. Do not uindertstand why I have
stat/Bridge/RESULT
tele/rf-bridge/RESULT
in my Sonoff RF Bridge the topic is rf-bridge
Take this with a grain of salt - I am VERY new to Home Assistant… but I think I see the problem.
In your sensor setup you have:
But in your MQTT message, the topic is:
So I believe you need to change your state_topic and replace “rf-bridge” with “Bridge”.
So it should should like this:
Now, whether you should be using the stat or tele topic, I don’t know yet - still learning all this.
Okay, found the Tasmota MQTT explanation - stat is correct for state change… tele is telemetry info - message sent at periodic interval.
I hope this helps!
… and that I am not completely wrong
mmhhh when I copIED/pasteD from a website it did it that way (it happened in the past too), but I did change in configuration with proper " (after using it though before correcting the error).
I changed my code as below, but still is not working (binary_sensor.14a_door_sensor does not change state in HASS)
