433mhz Fine offset wh2 External Component
With custom components going deprecated I decided to try my hand at converting my fine offset custom component to External Component, its mostly a copy and paste from different existing components but its working.
And might be a good starting point if you want to make a receiver for some different sensor.
just set the pin to whatever you have the 433 receiver connected to and you are set, then just change “if(data.id==99)” to the sensor you have and just copy and paste for more sensors.
https://github.com/flax2000/my-esphome-components/tree/main
esphome:
esp8266:
  board: esp01_1m
  framework:
    version: recommended
wifi:
  output_power: 12 #10-20
  power_save_mode: HIGH #HIGH NONE LIGHT
  fast_connect: true
  ssid: "xxxxxxxxxxx"
  password: "xxxxxxxxx"
  #use_address: minimal-tst.local
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
ota:
  - platform: esphome
external_components:
  source: github://flax2000/my-esphome-components@main
  components: [ rf_sensors ]
#  - source:
#      type: local
#      path: my_components
rf_sensors:
  pin: 3
  on_sensor_received:
          - lambda: |-
              ESP_LOGD("wh2", "wh2 id:%i tmp %.1f hum %.0f ", data.id, data.temperature, data.humidity);
              if(data.id==99)
                          id(wh2_temperature_).publish_state(data.temperature);
                          id(wh2_humidity_).publish_state(data.humidity);
  name: "wh2 temperature"
  unit_of_measurement: °C
  accuracy_decimals: 1
  device_class: "temperature"
  state_class: "measurement"
  filters:
    - median:
        window_size: 3
        send_every: 1
  name: "wh2 humidity"
  unit_of_measurement: '%'
  accuracy_decimals: 0
  device_class: "humidity"
  filters:
    - median:
        window_size: 3
        send_every: 1
