is it possible, to configure my Sonoff RF Bridge (flashed with ESPHome) to work with Humidity/Temperature sensor (CUL TCM97001)?
This sensors are sending via 433MHz their data to the main station.
What I did before:
ESPHome is flashed
my 433MHz rollershutter are configured and working fine
after starting the advanced sniffing, I’m able to see a log entry when the humidity/temperature sensor transmit data:
15:26:41 [I] [rf_bridge:077] Received RFBridge Advanced Code: length=0x06 protocol=0x0A code=0x5DB8631612
But I don’t know, if and how I can configure this as a sensor in ESPHome?
Is it a Sonoff RF bridge 433 ( black one) or a Sonoff RF bridge R2 (white one)?
The black one can be flashed with Portisch which will open up for more protocols.
AA B1 03 010E 00AA 0280 A09090909090909090 55 with temperature = 22.1 °C and humidity = 61% AA B1 03 0122 00B4 02C6 A09090909091909091 55 with temperature = 22,8 °C and humidity = 81% AA B1 03 00FA 00B4 02A8 A09090909090909090 55 with temperature = 23 °C and humidity = 91%
After some days, I had time to play again with this.
Now, I have the following advanced code. With help of an FHEM perl module, I was able to decode this:
0xE80863C580
E8 might be the ID, but I don’t checked it with other sensors yet
63C corresponds to the temperature of 20.8°C:
0x63C - 0x4c4 = 0x178 * 5 = 0x758 / 90 = 0xD0 => 20.8
58 corresponds to the humidity of 58%
But how can I configure an HT device in ESPHome, that every time the bridge receives this code, the entity in Home Assistant is updated?
