In most of the situations you wouldn’t need a casing. IR signal won’t pass through most of the ABS boxes, however 433 mhz would do (433mhz would go even through spray paint if you need a casing in a different colour).
I have all the components simply hanging on (without a breadboard). If trying to keep up with the development of the project you would need to remove the micro-controller at least twice per day for adding or removing components or flashing new firmware (it’s really not set and forget). At the moment the focus is on functionality rather than prettiness.
But if you’re really keen on keeping things tied up look on boxes of this size or larger (it is barely useful for NodeMCU without breaking any pin but for WeMos R1 mini is perfect):
Hi Petrica - thanks for the reply. I was just trying to make it more cosmetic (wife friendly!) if the breadboard etc is going to be sat in the lounge in view of the TV
If IR is the main culprit then use slightly longer cables to connect the IR receiver/blaster (have the main box outside view in a cabinet or taped right under the table) and then use isolating tape in the color of the furniture to cover the connecting cables. R1 mini are quite ok in terms of size.
You could point the IR blaster towards the device you want to control in a dead angle (as far I have seen it has a significantly reduced range than a regular, commercial IR remote but it would still go to 1 - 1.5 m).
Can anybody tell how to retain the sensor status when HA is restarted the state turn back to off even when windows is open when HA restarts.My configuration is like -
binary_sensor.yaml -
Any ideas why my Serial Monitor is completely blank? Baud etc are matched - everything compiled and uploaded ok. Have connection status of online:
home/OpenMQTTGateway/LWT Online
There isn’t much info provided. Try to check the entire chain (post printscreen/picture of modules if still not solved). Can think of the followings:
What baud rate have you used for serial monitor connection (not the one used for sketch uploading)? What is the software version loaded? What modules do you have (for gateway and for sensors)? Are the pins connected properly? etc
Are there any other messages in the MQTT topic from the gateway?
I’m unsure whether there is a watch-dog functionality in the gateway (most of the code it’s Chinese for me anyway ) however I’m using a cheap 433 Mhz socket to reboot one of the NodeMCUs. I have it connected with some other automation however you could do it as following. You can remove the entire condition part from the automation (I have different settings for night and day as during night receiving an IFTTT notification wouldn’t help me while I’m asleep ) thus it will restart regardless of the hour. Also, remove the first part from the action if you don’t have IFTTT set. Check the MQTT topic for the actual payload (remember that MQTT is case sensitive).
Hi people,
I could set the 433Mhz part and it’s working fine sending and receiving codes.
I was planning to add the garage door automation to HA using this gateway and it works fine triggering the door.
But I found a funny behavior on the other hand. As soon as a code is sent through the gateway, the hand held remotes got dramatically reduced in coverage. This is not happening after a reboot of the nodemcu while a code is not sent. As soon as a code is transmitted, I have to get to 1 meter or less to the door in order to make the remotes to work (tried 3 different ones and changed batteries also).
Looks like the transmitter keeps transmitting noise of something that causes interference on the receiver.
Another test performed was to remove the input pin of the Tx module and the issue dissapears inmediatly. As soon you connect it back, the issue is back if the node is not restarted, tried also several power sources to avoid ripple to cause the issue.
Any hint on what can be happening?.
Is there a way to mute or reset Tx after a code has been sent?.
Thanks!!
Adrian
Hi Petrica,
The modules I am using are cheap generic ones. I will have to purchase other ones to test if they are the cause. Note anyway the issue dissapears when the Tx module input is removed, but the module power is still on.
I will try other nodemcu’s just in case.
I don’t think the Tx module keeps transmitting codes after a command is sent, at least it is not repeating the same code, since the door is no stopped or reopened, but clearly there’s some interference present after the the code is transmitted. I don’t have an spectrum analyzer (whish I have one!!) or something to see what is being transmitted after the command is sent.
I’ll keep doing test and post the results. I would like to try also a way to disable or reset the Tx port on the code side to see if it helps.
Regards
Adrian
I’ve been using the latest build. And im having alot of disconnects with my nodemcu ESP8266-12f. I tryed different AP’s, tryed different nodemcu’s and all behaving the same way. With pinging I get huge latency (1000+ ms). After a while the ping becomes normal again. This repeates every 5-10 minutes.
