I don’t quite get what you mean. You can use either Mega (with Ethernet shield) OR ESP.
As a user of both RFLink@Mega and OMG@Arduino/ESP, I’d say that the easiest/cheapest/fastest way to have a play would be something like Wemos d1 mini - currently it is working as the main 433toMQTT bridge in my HA setup, and it does the job very well.
However, it’s better to check if a software of your choice supports your RF device as not all of them are standard and you might end up having 50-50 chance
I think what I meant was, RFLink seems to require an arduino board, and can use an ESP8266 for wifi connectivity.
Other solutions seem to just use an ESP8266 for same (or similar) function.
I’ve got a few boards lying around to play with though, so I’ll see how I go
- RFLink works on Arduino MEGA only.
- You connect the MEGA to RPi with a USB cable to get the information in HA, that the way it works
If you go OMG way though, your bridge needs to be connected to a network somehow anyway.
It can be Arduino UNO/MEGA/etc + a Ethernet shield.
It can be ESP8266 alone.
But I don’t think you can use Arduino with ESP as a network interface.
Hope it makes more sense.
For info OMG can be used on Sonoff RF Bridge with pilight, extending consequently the list of compatible protocols, here is how :
Hi, I’ve just found OpenMQTTGateway, is looks like a nice way of working with 433Mhz devices.
Is there a way I can get it to talk to my MQTT server using TLS?
Using Tasmota I use the fingerprint method here:
Can I do something similar using OpenMQTTGateway?
Ah OK, thanks for letting me know. I think I may be able to find some sort of workaround
Hi, hoping you could assist with a Sonoff RF Bridge?
Flashed RFBRIDGE_OpenMQTTGateway_V092.zip
Messed around a whole lot until I finally found that the default device name is OpenMQTTGateway_SRFB and not the default OpenMQTTGateway.
Got binary sensors working,
binary_sensor:
- platform: mqtt
state_topic: "home/OpenMQTTGateway_SRFB/LWT"
payload_on: "online"
payload_off: "offline"
device_class: "connectivity"
- platform: mqtt
state_topic: "home/OpenMQTTGateway_SRFB/SRFBtoMQTT"
value_template: "{{ value_json.value}}"
json_attributes_topic: '["protocol"]'
payload_on: "13655790"
payload_off: "13655783"
device_class: opening
- platform: mqtt
payload_on: "3624197"
off_delay: "1"
- platform: mqtt
payload_on: "15906678"
device_class: Motion
off_delay: "10"
Regular sensors,
- platform: mqtt
name: "Wifi OpenGateway 8266"
state_topic: "home/OpenMQTTGateway_SRFB/SYStoMQTT"
value_template: "{{ value_json.rssi}}"
json_attributes_topic: "home/OpenMQTTGateway_SRFB/SYStoMQTT"
- platform: mqtt
And lastly, a switch.
switch:
- platform: mqtt
state_topic: "home/OpenMQTTGateway_SRFB/MQTTtoSRFB"
command_topic: "home/OpenMQTTGateway_SRFB/commands/MQTTtoSRFB"
payload_off: "3624197"
optimistic: false
retain: false
The problems.
The sensor for input, used to keep showing data/codes. Now it disappears instantly, usually too quickly to highlight or copy. Mostly it’s just blank.
The switch seems to send. There’s a flicker on the RF LED on the Sonoff, but the receiving device doesn’t change/do anything. Tried with a RGB controller and a doorbell. (I can capture the remote codes via MQTTlens
Can’t read anything from serial monitor. Just prints rows of ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
I was using the Arduino IDE on 115200. -
Getting false readings on the motion sensor now. Shows motion, but there’s no movement in the room.
I had a nodemcu, and cheap rf kit previously. Same issue with the input sensor, and couldn’t send, but no false positives, and could read get data from serial monitor. Was thinking maybe my transmitter hardware was faulty, so I got the Sonoff today, but now I still can’t send…
Using Home assistant 0.96.5 and OpenMQTTGateway v0.9.2 as mentioned above.
Any ideas on how to resolve these?
Thanks in advance!
I suppose you see this behaviour on HA isn’t it? Could you check what is happening on the mqtt broker side and post the results?
Could you indicate the receiving device type/model?
For the sonoff rf bridge the speed has to be set to 19200
Could you post what you are seeing on the mqtt broker ?
Yes, it’s on Home Assistant, and using this broker, which mainly just shows connections.
Logbook also doesn’t show the code, just a blank space.
Do now have serial monitor so when pressing the doorbell button:
Creating SRFB buffer
isAdupl?
Adv data SRFBtoMQTT
Pub json into:
{"raw":"147800B40208374D05","delay":5240,"val_Tlow":180,"val_Thigh":520,"value":3624197}
Pub data per topic
raw
147800B40208374D05
delay
5240
val_Tlow
180
val_Thigh
520
value
3624197
Store val
Min ind:
0
store code :
3624197/43895
Col: val/timestamp
0:3624197/43895
1:0/0
2:0/0
3:0/0
4:0/0
5:0/0
6:0/0
7:0/0
8:0/0
9:0/0
10:0/0
11:0/0
[RFBRIDGE] Sending ACK
MQTTlens for button as well.
"raw": "145000BE0208374D05",
"delay": 5200,
"val_Tlow": 190,
"val_Thigh": 520,
"value": 3624197
And then serial monitor when I activate the switch to send same signal as received above.
Hey I got a callback
MQTTtoSRFB prts
[RFBRIDGE] Sending MESSAGE '%s' %d time(s)
⸮⸮%@⸮7MU
And MQTTlens for switch too.
Doorbell is a “local” SA brand. Ellies. Not a super lot of info.
RGB Controller is one of these
If I can receive the codes, I should be able to send them as well, or is there something regarding RF I’m missing?
This is working now, thanks!
I’ll keep an eye on the false readings issue. Hasn’t happened again today.
Does any of this help narrow down the issue with sending? From the serial monitor log is does seem like something’s going wrong.
Thanks again!
Regarding the sensor it seems to be related to HA configuration, did you tried this configuration
Regarding MQTTtoSRFB did you uncommented simpleReceiving in your configuration (user_config.h) indeed your yaml definition correspond to simpleReceiving and per default OMG expect json.
You can either uncomment simpleReceiving or modify your yaml to make HA send json.
I did try those, but get errors relating to json_attributes needing to be updated to
json_attributes_topic. If I change my sensor from “value” to any of those others, (version/uptime/etc) it works, and displays without disappearing.
MQTTtoSRFB - I didn’t un-comment anything. Just flashed the pre-compiled .bin file.
What was the default set to on RFBRIDGE_OpenMQTTGateway_V092.zip?
Thanks!
Does the value disappearing event correspond to an mqtt publication ?
You could subscribe to all the subjects to see that. Or maybe use mqtt explorer.
I m suspecting that simplePublishing overwrite the values of jsonPublishing.
For info I have removed simplePublishing from binaries file, you can try to upload again if you want to see if it was due to that.
Hi, thanks. I’ve managed with Tasmota for now, but I’ll try this on my other setup. Which bin was modified?
All were modified. Indeed there is no need of simplePublishing per default.
A new board compatible with OpenMQTTGateway :
Something happened to the images at the site/blog. May you check, plz?
Thanks for pointing that, issue corrected!
just installed your project @1technophile and almost got it working!
The following code allows me to sync the HA switch to the button presses on my remote. However, the actual HA switch immediatly reverts to off when i try and switch it on. I does actually turn on my outlet/plug but the state is wrong. The state moves to the ON position if i press my remote.
Any ideas?
- platform: mqtt
state_topic: OMG/OpenMQTTGateway/433toMQTT
command_topic: OMG/OpenMQTTGateway/commands/MQTTto433
value_template: '{{ value_json.value}}'
payload_on: 13451403
payload_off: 13451402
# state_on: 13451403
# state_off: 13451402
# optimistic: true
retain: true
qos: "0"
