Eeeeeediot:
# optimistic: true
Maybe others HA expert will have a better advice but I think you should set the optimistic
value to false
so as to take into the gateway feedback.
But first, your states seems to be commented, I will uncomment them before changing the optimistic parameter. It is possible that HA go into optimistic mode per default as it can’t see the expected state values.
Hey,
Thanks for your speedy response - got it working now!
I set up 6 variations of the switch with different quotes, some as strongs, some as values etc… and in the end they all work which is quite frustrating for a beginner that 6 different versions of a code all do the same thing!
Thank you so much!
- platform: mqtt
state_topic: OMG/OpenMQTTGateway/433toMQTT
command_topic: OMG/OpenMQTTGateway/commands/MQTTto433
value_template: '{{ value_json.value}}'
payload_on: '{"value":"13451403","protocol":"1","length":"24","delay":"212"}'
payload_off: '{"value":"13451402","protocol":"1","length":"24","delay":"212"}'
state_on: "13451403"
state_off: "13451402"
# optimistic: true
retain: true
qos: "0"
#dont toggle
- platform: mqtt
payload_on: '{"value":13451403,"protocol":1,"length":24,"delay":212}'
payload_off: '{"value":13451402,"protocol":1,"length":24,"delay":212}'
# optimistic: true
retain: true
qos: "0"
# dont toggle
- platform: mqtt
payload_on: '{"value":"13451403"}'
payload_off: '{"value":"13451402"}'
# optimistic: true
retain: true
qos: "0"
# dont toggle
- platform: mqtt
state_on: 13451403
state_off: 13451402
# optimistic: true
retain: true
qos: "0"
- platform: mqtt
payload_on: '{"value":13451403}'
payload_off: '{"value":13451402}'
# optimistic: true
retain: true
qos: "0"
- platform: mqtt
state_on: 13451403
state_off: 13451402
# optimistic: true
retain: true
qos: "0"
vasarbob
(Robert cunningham)
May 13, 2021, 2:03am
708
Can you use two transmitters on the one esp8266. RF transmitter and a IR on the same board. Both on different pins and using the same library ?
Yes you can have an IR transmitter and an RF transmitter on the same board. You can also add an RF receiver and an IR receiver.
