Hi. I have been using home-assistant for a while now and I’m quite satisfied with it.
I works well for my needs except fore one feature that I’m missing.
I have a number of legacy 433MHz devices that I’m using with an Rfxcom in home-assistant, so far all is god. But the thing is that the object in home-assistant representing the 433 remotes don’t let me trigger s riots when repeatedly pressing the same button on a 433 remote.
E.g. when pressing the off button a script runs which I turning off all lamps. If I after 30 min again presses the off button nothing will happen because the on button was not pressed before.
Is there any way that I can change this behavior?
Regards
Per-Arne
