I think you would have better battery life with moteinos but i need some input about zwave battery life before confirming that.
Regarding the 0.4 you can add a dht with i2c if you connect it to D5 you will have to change the pin definition into the program. It is not available by default due to the fact that with i2c you can plug temperature sensor or other sensors to the bus.
I have few z-wave sensors and I started to use them since May 2016. If remember I only changed the battery once.
Anyway, regarding the I2C modules, can I use both BME280 and BH1750 in the same gateway? I need to measure both light and temperature.
I just tested with both DHT22 and BH1750. Guess what? Both are working!
Is there any wireless, independent (433 Mhz) LDR sensor?
For temperature and humidity there are weather station remotes on 433 Mhz, however for LDR I havenāt seen a similar solution.
I would be reluctant in placing a NodeMCU in environments with high temp, high moisture (such as in a bathroom). Even with DYI waterproofing Iām not comfortable with cables carrying more than 5V (there was also that guy who got electrocuted in the bathroom when using the iPhone charger).
Yes you can use several i2c sensors on the same wiring
i have problem with 433toMQTT with NodeMCU,
i have MQTT communication between HA and the Node, but for some reason there is no rf signal receive or transmit from the Nodeā¦
can anyone help with this one?
Please post to 433mhz, infrared IR to and from MQTT on ESP8266
The current post is dedicated to Arduino setup and no NodeMCU
Regarding your issue do you see on the serial monitor "MQTTtoRF " in the serial monitor
Did you checked the troubleshooting section?
HI,
i managed to solve this issue, now i can get the MQTT massage via mosquito but i didnāt succeed with configuration it to trigger event in HA.
my goal is to make an rf wall switch to trigger rf relay and to show status of the relay in the UI,(i know all about the un reliable with rf statusā¦)
i managed to control the relay via HA with MQTT. but this is where im stuck atā¦
@HA-PI:~ $ sudo mosquitto_sub -t home/# -v
home/OpenMQTTGateway/LWT Online
home/commands/MQTTto433/PLSL_247/433_1 8496001
home/433toMQTT/protocol 1
home/433toMQTT/bits 24
home/433toMQTT/length 473
home/433toMQTT 5595072
this is my input from MQTT when pressed on the RF switch.
Good I am new in all this world, you could share me the script (script.officemot) to be able to understand it. Thank you
Sure @EAN . Here is my office motion script.
script:
officemot:
alias: Office Motion
# Cancel ev. old timers
- service: script.turn_off
entity_id: script.officetimeoff
- delay:
seconds: 5
- service: homeassistant.turn_on
entity_id: group.office
# Set new timer
- service: script.turn_on
officetimeoff:
alias: "Turn off office after 10 minutes"
- delay:
minutes: 10
- service: homeassistant.turn_off
I think I posted the spacing right but check to make sure. Good Luck.
I have been using this project for some time, fantastic bit of kit. I do have an issue however.
I have recently added 3 door sensors that send both open, and closed codes. That part works perfectly. The issue is when HA is restarted, if a door is open, it will revert back to closed on reboot. The open status does not seem to be retained.
This is the binary_sensor I have set up for one of the doors.
- platform: mqtt
qos: 1 # I have tried 0 for this as well
state_topic: "home/433toMQTT"
payload_on: "12510986"
payload_off: "12510990"
device_class: door
retain: true
I have even tried using an automation to publish the state on change to attempt to have it retained, no joy.
- alias: Set State of Front Door
platform: state
entity_id: binary_sensor.front_door
to: 'on'
service: mqtt.publish
topic: 'home/433toMQTT'
payload: '12510986'
retain: true
Is there something obvious I am doing wrong?
There is nothing wrong with your settings. OpenMQTT is set to publish without retain flag.
Your automation to publish the state is on the wright track, however you might want to use another topic for publishing in order not to get confused as the home/433toMQTT gets overwritten each time a new message is received (and it is not retained, thus when restarting HA it is blank). There are a few components that support restore state however binary sensor is not among them.
- alias: Set State of Front Door on
platform: state
to: 'on'
topic: 'home/devices/frontdoor'
payload: 'on'
retain: true
- alias: Set State of Front Door off
platform: state
to: 'off'
payload: 'off'
retain: true
and then the binary sensor (the one that you have would become an intermediate sensor and you can hide it from HA):
- platform: mqtt
name: "Front Door Modified"
qos: 0
state_topic: 'home/devices/frontdoor'
payload_on: "on"
payload_off: "off"
device_class: door
Actually, you can use a single automation in order to reduce number of entities managed by HA (as the trigger would look for changes in the binary sensor or not set an intermediate binary sensor after all, but in this case it needs the condition part to look for either payloads on or off - 12510986 or 12510990). Are you comfortable with that?
@Petrica Thanks for the reply. I had assumed that the retain flag wasnāt being sent. This is something that would be very beneficial to be added in, however.
I will adjust my automation and see how I go. Thanks again.
@Petrica I think I have it sorted, thanks for the suggestions. Here is my config, just using one door sensor as an example. I have a single automation covering all the open/close events for all 3 doors (I think)
binary_sensor.yaml
- platform: mqtt
qos: 0
- platform: mqtt
qos: 0
state_topic: 'home/door'
device_class: door
retain: true
automation.yaml
# DOOR STATE #
- alias: Door State
initial_state: True
platform: mqtt
topic: home/433toMQTT
data_template:
topic: "home/door"
payload_template: '{{ trigger.payload }}'
retain: true
Yes, one automation to rule them all
Except you would need to change the other two mqtt binary sensors to monitor āhome/doorā topic too. There is no need for any binary sensor to monitor āhome/433toMQTTā topic anymore (you end up with one automation as the sole overhead).
Look to Mqtt.py log warning "No matching payload found for entity" for description of the log warnings that you will going to have
Yes, I have all 3 doors using the /home/door topic, I think that is what you mean?
The problem now is I need to write an automation to have the home/433toMQTT
binary sensor grab the state of the /home/door
binary sensor as when I reboot twice, the state is lost again as the 433toMQTT
binary sensor resets at boot. I hope that makes sense.
You only need to keep the automation from above.
The binary sensors will become as following:
- platform: mqtt
qos: 0
device_class: door
retain: true
- platform: mqtt
name: "Other Door 1"
qos: 0
payload_on: "11111"
payload_off: "22222"
device_class: door
retain: true
- platform: mqtt
name: "Other Door 2"
qos: 0
payload_on: "33333"
payload_off: "44444"
device_class: door
retain: true
But again, this is a quick and dirty fix (the downside is that if the doors are opening/closing while HA is restarting then the state will be in topic āhome/433toMQTTā; because automation is not working until HA is up again the topic āhome/doorā is not being updated).
The best way would be to have OpenMQTT publishing with Retain flag (and thus to have binary sensors monitor āhome/433toMQTTā again).
