Thanks a lot Petrica.
I just read in some place that the R8H units can be at max 3 pieces in same place.
Cause everione can be set from 1 to 3 … is that true please ?
I think that the best solution can be to make from zero an arduino
with temp/humidity sensor and RF module.
All this in order to make it work with 433toMQTTto433 or the Pilight
Put all in sleep mode and wake it up only 5 minutes.
In this case with 2 batts of 1,5V maybe will work one year.
The sensor has a switch with 3 positions to choose from 3 channels. Actually I think that this refers to the fact that, from the factory, they have the ability to set a single ID to a batch of devices, then each device will provide its unique key by changing the channel case there are two units with the same ID.
I don’t know anything about their production process in order to compute probability for more than 3 devices in the same batch sent to customers to share the same ID, but I guess it would be quite low.
Haven’t looked too much into a 433toMQTTto433 option but I think there might be solutions such as Zigbee that are optimized for low power, even lower data transmission (but permanently connected with gateway), that could offer years of a LR2450 battery.
The problema is that I don’t know why… but I don’t like the Zigbee
Maybe cause in moy house I allready habe BT + WiFi + RF433 … a lot of radio.
So I don’t want to add also Zigbee.
In the mean time that Florian will apply the R8H ,
and because I have a lot of time this mouths cause I work from home (corona)
I will search and study some projects that can be usefull in my case.
What I want is to put a temp/humidity sensor in all my rooms and also outside
in my greenhouse and in the chicken coop… and all this sensor data I want to have it
in the Hassio (Node-Red) in order to make some rutines.
So because I so that you are a guru in this thinks I ask you permission to vrite you privatelly
and maybe when you have some minutes we can talk about at phone (I’m in Italy)
I’m not familiar with Node-Red as I only use yaml automations (since I don’t work in IT, I had no previous programming experience to compare with writing yaml automations), but once the sensor data is in, then I guess there would not be any issue with NR.
Thanks a lot Florian,
but I just want to use same sensor in all my house+garden+greenhouse
so I need a little long range sensors.
On OMG forum I just open a thread when I ask some help in order to make a sensor by DIY
that can “talk” with OMG. Please take a look if you have some time.
Thanks a lot
(Mersi mult )
Must go out from my house trought a wall, and then about 50-60 Mt. in a free field.
I just find this post that is greate to learn in order to make my sensor
But I must change the RF module cause that one I think work only inside house.
Thanks a lot for the link,
but I think this module is too big and expensive in order to make all home sensors using it.
But you give me a new idea for the BLE sensors… cause I find this one from Xiaomi
that cost less and il a lot simpatic
So as far as I know the OMG work well with BLE sensors.
So now I’ll decide if… I’ll make a DIY sensor module (like I post here)
or I’ll buy some of this sensors and I’ll make a OMG for every zone where BLE distance is not arrive.
Anyway the best sensor may be a DIY on atmel based (with all powerdown/sleep mode),
wake it up every 3-5 minutes, take data from temp/humidity sensor, update the numbers on
little nice e-link dispay, send data via a good RF 433Mhz to OMG and back to sleep again.
The one that you make is great… but need to add better RF module and maybe a better temp/humidity one.
Maybe is time to uodate that page
