I have Zigbee-enabled GE smart dimmers. They show up fine in the Lovelace interface. I can check the state of on or dim by the icon and by the slider. These change if I move the slider.
My problem is I have an automation to turn on one of these for the front door at dusk and off at dawn. This works fine, but I can’t seem to manually edit to add a brightness value to adjust the light, as I want about 40 pct bright. I will use an automation with a motion detector to make the light go 100 pct.
I’ve tried a few of the suggestions for the brightness value under the action, but while the configurator check says the syntax is OK, automations won’t restart.
Any ideas? Are these specific dimmers different? How can I list all the entities for this device? Because it’s Zigbee, it’s not as easy to interrogate the device, as it is with Z-Wave.
