Love it ⌠looks like your are getting the hang of the blueprint⌠nice work and thanks for the update.
Blacky
Blacky
FAQ: How to use the Ambient Options
This option is used to add a condition that only allows the automation to run when it is dark or below the âAmbientâ settings. Itâs a global condition that can work alongside other options.
Ambient Light Sensor
Consider utilizing a primary outdoor sensor to detect the actual outdoor LUX value. This approach can be beneficial as it allows for the use of a single sensor across all your lighting automation setups. You may opt to use indoor sensors when the outdoor LUX value becomes irrelevant, such as when using lights in your garage with the door closed or when closing blinds in rooms. Itâs really up to you and what suits your site conditions best.
Ambient Light Sensor - Site Conditions
In some cases when your lights turn ON, your ambient light sensor is affected, increasing its LUX value. This can cause the lights to go OFF prematurely. Please select an option that best suits your installation.
NOTE - If using an buffer zone between the high and low lux value, then please select NO.
Ambient Light - Low & High Lux Value
Having both a Low and High Lux value setting allows you to establish a buffer zone between the two. The Low value determines when the trigger is activated and the lights turn ON, potentially increasing the Lux value in the room. Conversely, the High value prevents immediate light deactivation, serving as a buffer zone to accommodate Lux fluctuations without turning off the lights instantly.
Ambient Light - Low Lux Value
Set the Ambient Light Low Lux Value. The light will turn ON when the lux level is below the set value. This value must be equal or lower than the âHigh Lux Valueâ below. Guide is 20 lux (dusk).
Ambient Light - High Lux Value
Set the Ambient Light High Lux Value. The light will turn OFF when the lux level is above the set value. This value must be equal or higher than the âLow Lux Valueâ above. Setting a value higher than the low value allows for an offset. Guide is 80 lux (dawn).
Enjoy
Blacky
Back to FAQ: Click Here
Back to âThe Settings & Best Practice Guidelinesâ Click Here
I will look out for it. though the last one is screenshot for Utility room failed and is also a simple light and motion sensor. no Night mode, just on and off.
Just shifted all the ones with scenes to a simple light. Using the relevent colour and brightness levels.
They donât survive a restart. Just stay permanently on.
Could it be that because the lights are on a zigbee2mqtt connection that the automation starts too soon, before the lights state is recognised as being on?
Perhaps a longer or configurable delay is needed to deal with how long it takes HASS to settle after a reboot?
That could be the case. In this next update maybe try and put in some toggle helpers into âScenes & Scripts - Toggle Helperâ.
Let me know if that works.
Blacky
Your lighting experience, your way â take control and customize it to perfection!
New Feature
Changes to Scenes & Scripts
We have added three new inputs.
The purpose of adding these inputs is to ensure the proper functioning of automations when using scenes or scripts. The benefits of adding these inputs include:
Maintenance
If you like this blueprint? Consider hitting the button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Enjoy
Blacky
Awesome @Blacky I do have a feature request for your add-on movie theater blueprint. Reedâs smart home on YouTube had a new video that does a similar thing to your blueprint, BUT he added the ability to have different lights/scenes based on the app on the Apple TV or Chomecast that is open. For example, for Spotify or Apple Music you could not dim the lights, but with Netflix, do a full movie dim. I think app specific conditions would be amazing.
FAQ - How To Create A Toggle Helper?
When using scenes and scripts, it is recommended that you create a toggle helper. Below, Iâll show you how to do this.
Go to Settings / Devices & Services / click on the âHelpersâ tab at the top / create helper and select toggle.
Input the name you would like to call it, select an icon if you like and click create.
Enjoy
Blacky
FAQ - How To Create A Schedule Helper?
FAQ - How can I to turn the light on at sunset but turn them OFF at a set time?
You can use a schedule helper as the trigger. Below, Iâll show you how to do this.
If you would like to turn your your lights, switches, scenes, or scripts ON when the sun sets, then you would select a time well before the sunset and enable the sun condition. This ensures that the trigger is ON well before the sun sets but waits for the sun condition to turn your light ON. Then, the schedule will turn your lights OFF as per your schedule.
Example
This will activate your lights, switches, scenes, or scripts when the sun elevation is below -1.5 because the trigger schedule is active having an ON time 4pm. Conversely, it will deactivate them at the end of your schedule, well before the sun rises above -4.0.
Enjoy
Blacky
I have a timing problem that I need help with.
I would like the automation to be active between 5 am am 8 am, than again from 4 pm to 9 pm. The automation is off otherwise. How can I achieve this? Time settings only allow one time range. I need it to be triggered by the motion Detector, so a schedule helper doesnât seem to be the answer.
You can use a schedule helper but your ON time will be the opposite to when you would like the automation to be active. Then you would put the schedule helper into the bypass option 2. Below is a example of the schedule. Then you wouldnât use the time option
Blacky
This is just great. Just what I needed. Thank you so much for this.
Unfortunately I think I may have found a bug in Version 5.9 of this blueprint. This will prevent to turn ON lights using bypass ON.
To reproduce use blueprint with scripts to turn on, therefore a toggle helper and a bypass ON and bypass OFF helper.
Expected
The light turns on again.
best regards
Actual
The light stays off. I noticed, the toggle helper is still on. If I turn the toggle helper off manually, the lights turn on again.
Thank you. That works great!
Yep you are correct there is a bug in the bypass when using scripts and scenes. Sorry about that ⌠I will have to fix this ASAP.
Thanks for letting me know and keep an eye out for the next update.
Blacky
You just rock. Thanks so much
This has been resolved, a new update is coming out now. Let us know if I got everything.
Again thanks for your help.
Blacky
Bugs Fixes
Enjoy
Blacky
Thanks for all this, looks great. Havenât made it work yet. Can the entity be a dimmer switch? If so, how is the light level set?
