That could be the case. In this next update maybe try and put in some toggle helpers into āScenes & Scripts - Toggle Helperā.
Let me know if that works.
Blacky
Blacky
Your lighting experience, your way ā take control and customize it to perfection!
New Feature
Changes to Scenes & Scripts
We have added three new inputs.
The purpose of adding these inputs is to ensure the proper functioning of automations when using scenes or scripts. The benefits of adding these inputs include:
Maintenance
If you like this blueprint? Consider hitting the button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Enjoy
Blacky
Awesome @Blacky I do have a feature request for your add-on movie theater blueprint. Reedās smart home on YouTube had a new video that does a similar thing to your blueprint, BUT he added the ability to have different lights/scenes based on the app on the Apple TV or Chomecast that is open. For example, for Spotify or Apple Music you could not dim the lights, but with Netflix, do a full movie dim. I think app specific conditions would be amazing.
FAQ - How To Create A Toggle Helper?
When using scenes and scripts, it is recommended that you create a toggle helper. Below, Iāll show you how to do this.
Go to Settings / Devices & Services / click on the āHelpersā tab at the top / create helper and select toggle.
Input the name you would like to call it, select an icon if you like and click create.
Enjoy
Blacky
Back to FAQ: Click Here
Back to āThe Settings & Best Practice Guidelinesā Click Here
FAQ - How To Create A Schedule Helper?
FAQ - How can I to turn the light on at sunset but turn them OFF at a set time?
You can use a schedule helper as the trigger. Below, Iāll show you how to do this.
If you would like to turn your your lights, switches, scenes, or scripts ON when the sun sets, then you would select a time well before the sunset and enable the sun condition. This ensures that the trigger is ON well before the sun sets but waits for the sun condition to turn your light ON. Then, the schedule will turn your lights OFF as per your schedule.
Example
This will activate your lights, switches, scenes, or scripts when the sun elevation is below -1.5 because the trigger schedule is active having an ON time 4pm. Conversely, it will deactivate them at the end of your schedule, well before the sun rises above -4.0.
Enjoy
Blacky
I have a timing problem that I need help with.
I would like the automation to be active between 5 am am 8 am, than again from 4 pm to 9 pm. The automation is off otherwise. How can I achieve this? Time settings only allow one time range. I need it to be triggered by the motion Detector, so a schedule helper doesnāt seem to be the answer.
You can use a schedule helper but your ON time will be the opposite to when you would like the automation to be active. Then you would put the schedule helper into the bypass option 2. Below is a example of the schedule. Then you wouldnāt use the time option
Blacky
This is just great. Just what I needed. Thank you so much for this.
Unfortunately I think I may have found a bug in Version 5.9 of this blueprint. This will prevent to turn ON lights using bypass ON.
To reproduce use blueprint with scripts to turn on, therefore a toggle helper and a bypass ON and bypass OFF helper.
Expected
The light turns on again.
best regards
Actual
The light stays off. I noticed, the toggle helper is still on. If I turn the toggle helper off manually, the lights turn on again.
Thank you. That works great!
Yep you are correct there is a bug in the bypass when using scripts and scenes. Sorry about that ā¦ I will have to fix this ASAP.
Thanks for letting me know and keep an eye out for the next update.
Blacky
You just rock. Thanks so much
This has been resolved, a new update is coming out now. Let us know if I got everything.
Again thanks for your help.
Blacky
Bugs Fixes
Enjoy
Blacky
Thanks for all this, looks great. Havenāt made it work yet. Can the entity be a dimmer switch? If so, how is the light level set?
If you can use HA to adjust the brightness then you should be good to go.
Try it out and let me know how you go.
Blacky
Itās probably me and my settings, and unfortunately I have to ask questions now.
Version 5.9.
I have the lights first half of the blueprint working fine for P1 Aqara Sensor detects motion, turn on light 100%.
Time mode, 6 PM to 9 PM. Adjusted to test.
Green entity bedroom bulb.
Works every night.
Trigger is Aqara P1 motion sensor.
That worked and still works if I change the times to test and turn off/disable night lights.
I also had nightlight working for one night.
That has stopped working.
Also time based. 9 PM to 6 AM
Green entity, same bedroom bulb.
Even if time is changed to now time and tested.
Iābe used do not disturb as a night light entity state.
I think I used the same motion sensor as the toggle on night lights seemed to work for one night. So many changes and tests I donāt remember. Lol
Rearranging the times and toggling DND to test night. Nothing.
P1 is always detecting motion and occupancy, not using occupancy, only motion. They both clear also.
Iāve tried DND as the night toggle, battery charging, the same motion sensor etc. If I manually run the automation, you can see the bulb is at 20 percent, times out, goes out, but wont fire again if time is adjusted and savedā¦
I am getting an error occasionally which Iām too newb to ID. And may or may not even be associated. But only a couple of times. No clue.
My apologies, Iām a newb to HA anything, but learning fast.
yes, this works in HA already as a scene triggered by the motion detector.
But with this blueprint I tried setting it with the motion detector as the trigger and the dimmer as the entity but nothing happens. But I donāt see where to tell it what the dimmer should do, what the brightness should be. I tried the Light Control options. What else should I try? TIA
Further testing today for night lights.
Set time and entity state on in night lights.
Used the same motion sensor occupancy as the turn on for night lights.
Same physical sensor as motion, which triggers lights at the top of the blueprint.
Maybe there be a trigger race, maybe not. Iāll know tonight.
