4CH Pro R2 will not trigger from Homeassistant
Hi guys, this is my first post and I have just started using HA.
I currently have 8 sonoff basics running Tasmota and they all are working well but my problem started with the 4CH Pro R2, Flash went well and i can get on to the web interface, entered mqtt like i have with all other basics, adjusted the S6 switch to 1 and flicked all K5 switches to 1. relays work perfectly from the box itself and also from the Web Interface. It also work from TasmoAdmin withen HA. But no matter what i do, I cannot for the life of me get it to run with HA. Used switch, light… you name it.
Here is a copy of my code. Sorry if this post is messed up, mu first time.
  - platform: mqtt
    command_topic: "cmnd/Sonoff4CH/power1"
    state_topic: "stat/Sonoff4CH/POWER1"
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
  - platform: mqtt
    command_topic: "cmnd/Sonoff4CH/power2"
    state_topic: "stat/Sonoff4CH/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
Any idea what I am doing wrong guys.
for the command topic, try setting the power part to capitalised
Thank you for the reply, I have tried that too.
What confuse me is that all other Basic sonoffs work perfectly, but this 4ch just will not do anything when i move the switch.
on the console on the sonoff, does it have any information as to what topics have been used
could you also not enable discovery on the sonoff and then HA will populate automatically?
enter SetOption19 1 in the console to enable it
The console reports exactly the topic i used in mqtt on the sonoff portal, I have tried SetOption 19 but HA never discovered it. I also do prefer to do it manual config to have more control.
Also i removed mqtt fully and re configured it just to see if i missed anything.
Also I have re flashed the 4CH Pro
I can see in mqtt log that my 4CH Ip address makes a connection
If discovery does not work did you remember to add the discovery option in your HA config?
The bottom two lines.
mqtt:
  broker: !secret host
  port: 1883
  keepalive: 60
  username: !secret mqtt_name
  password: !secret mqtt_pass
  discovery: true
  discovery_prefix: homeassistant
For my non discovery devices this is how mine are set Like @aidbish mention I have POWER1 command part in capitals. I also have the availability_topic set, but I dont know if that is relevant to your issue or not.
  - platform: mqtt
    state_topic: "stat/PrStrLivingRoom/POWER1"
    command_topic: "cmnd/PrStrLivingRoom/POWER1"
    availability_topic: "tele/PrStrLivingRoom/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: false
  - platform: mqtt
    state_topic: "stat/PrStrLivingRoom/POWER5"
    command_topic: "cmnd/PrStrLivingRoom/POWER5"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
    icon: mdi:usb
Thank you guys, I will start testing and I will get back with results!
Semi Succses !!
I followed your instructions to add the discovery and sure enough, it got discovered by HA as a switch and a button (BTN).
Now the challenge of adding it manual, I have no clue where the discovered items get stored, to at least read how HA reads it.
Any info will help, thanks again guys.
They go into .storage/core.device_registry
But I am changing mine back to non discovered as I can name them better
I would also like to change this switch to non discovered, so if you find the way, please share :slight_smile:
And thanks again for location.
SetOption19 0 in the console on the Sonoff
Ok i give up…i did the setting in sonoff console to remove auto detect, and tried to set it up manually again. I get Unavailable in the switch card.
I think it uses another topic name than the mqtt that i have imputed in sonoff console.
wills106 if you get it working on manual, please share :slight_smile:
Thanks all and for now it will be on auto discover…
Normally you would only config POWER1 to POWER4, but I am using a custom setup with a 5th relay.
configuration.yaml
mqtt:
  port: 1883
  keepalive: 60
#I have part of it setup under the light component
light:
  - platform: mqtt
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
#Other parts are just switches
switch:
  - platform: mqtt
    state_topic: "stat/PrStrLivingRoom/POWER4"
    command_topic: "cmnd/PrStrLivingRoom/POWER4"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
  - platform: mqtt
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
    icon: mdi:usb
automations.yaml
#Check Power Status on startup for Sonoff Devices
- alias: "Power state on HA start-up"
    platform: homeassistant
    event: start
    - service: mqtt.publish
        topic: "cmnd/sonoffs/power1"
        payload: ""
        topic: "cmnd/sonoffs/power2"
        payload: ""
        topic: "cmnd/sonoffs/Power3"
        payload: ""
        topic: "cmnd/sonoffs/power4"
        payload: ""
        topic: "cmnd/sonoffs/power5"
        payload: ""
The setup on my Sonoff it’s self.
Sadly didnt work for me, here is my code for the first switch only
  - platform: mqtt
    command_topic: "cmnd/Sonoff4CH/POWER1"
    availability_topic: "tele/Sonoff4CH/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
You have your Full Topic back to front it should be %prefix%/%topic%/
hmm how did that happen, let me fix and get back !
@wills106 Your a star! Thank you so much, finally its working as it should!! :grinning::grinning::grinning:
woooohoooo!
Glad you got it sorted.
Have you been trying out different firmware’s on that device? As 2 of my wall switches had the same problem where the Full Topic got reversed for some reason. The only thing that I think could have caused it on mine was swapping about on different firmware’s.
