I have 2 LED (Warm white) cealing lights (rectangles) controlled by 0-10v dimmers, hidden from view there are RGB ws2812 ledstrings on top of them. and 1 touch button
my issue(s) are a bit misty though
- the touchbutton only controlls the visable lights (both) starting at 60% with a short press, long press → in 10 steps 70,80,90,100, 10,20,30,40,50,60 wait few sec before pressing again.
- if any lights are on though the short press should turn everything off
this part works “kind off”, but for RGB (and effects) it seems easier to do it via the HA interface (will be a secret control added via alternative method) also individual light control will be done via HA
My biggest issue is that the values are not updated in HA and web_portal on state changes.
I have added down below my Yaml file
# board esp32-wroom-32
# pins used (soldering)
# pwm pin(s) 2x (pwmpin1 + pwmpin2 )
# rgb LED 2x (pwmpin3 + pwmpin4 )
# power supply switch 4x ( relaypin1, relaypin2, relaypin3, relaypin4)
# touch button
# note:
# when attaching ledstring(s) start with DI (data in) and where DO (Data Out) ends you normally attached the next/second ledstring
# however where if this is the second pin you are using attach it to the same data in as where you would connect from A to B
# this should be clear when you run a "snake or moving light effect", this is not intended as a display though
# button to trigger 2 things
# short press open door (if party mode is enabled, no tags needed)
# long press = battery status
# in HA & webinterface all devices are individually controlled
# via ESP (direct physical controll )
# the touch sensor starts at level 60 (turned on) and turns off ledstring via "template main switch"
# then cycles in steps 10% except 0 = off, if higher then 100% then set to 10%
# when light is turned on --> relay(pins) get triggerd --> then light
# ledc controlles PWM 0-10v boards
# fastled_clockless controlls ledstring(s)
##### PWM 0-5v or 0-10v
# using PWM pin gives 0-1v maybe dac channels ?
# https://esphome.io/components/output/esp32_dac.html
# https://deploy-preview-2901--esphome.netlify.app/components/output/gp8403
substitutions:
###### Board specifics
core: dev
arduino: recommended
platform: ESP32
board: nodemcu-32s # https://esphome.io/devices/nodemcu_esp32.html ESP32-DevkitC
###### web portal
web_port: "80"
web_version: "2"
###### Identity
devicename: atticlight
friendlyname: Attic Light Controller
upper_devicename: AtticLight
logger_level: DEBUG # default DEBUG, options = NONE,ERROR,WARN,INFO,VERBOSE,VERY_VERBOSE
# https://esphome.io/components/logger.html?highlight=logger
###### Pins
pwmpin1: GPIO21 # light1 (0-10v light1)
pwmpin2: GPIO33 # light2 (0-10v light2)
pwmpin3: GPIO19 # light3 (ledstrip 1)
pwmpin4: GPIO18 # light4 (ledstrip 2)
relaypin1: GPIO17 # Relay1,comm = vcc,NO = light1
relaypin2: GPIO16 # Relay2,comm = vcc,NO = light2
relaypin3: GPIO04 # Relay3,comm = vcc,NO = light3
relaypin4: GPIO26 # Relay4,comm = vcc,NO = light4
touchpin1: GPIO32 # Touch sensor
###### Variables:
DefaultLightSetting: "60"
# set some globals when system boots up
globals:
- id: light1setpercentpwm
type: float
restore_value: no
initial_value: "0"
- id: light2setpercentpwm
type: float
restore_value: no
initial_value: "0"
- id: light3setpercentpwm
type: float
restore_value: no
initial_value: "0"
- id: light4setpercentpwm
type: float
restore_value: no
initial_value: "0"
- id: MainLightClick
type: int
restore_value: no
initial_value: $DefaultLightSetting
- id: a1stLightClick
type: int
restore_value: no
initial_value: "0"
- id: a2ndLightClick
type: int
restore_value: no
initial_value: "0"
esphome:
friendly_name: $friendlyname
on_boot:
then:
- script.execute: boot_script
project:
version: "1.1.0"
esp32:
board: $board
framework:
type: arduino
# Enable logging
logger:
level: $logger_level
script:
- id: boot_script
then:
- logger.log:
format: "Boot_script started"
level: INFO
- logger.log:
format: "Waiting for API connection"
level: INFO
- wait_until:
condition:
api.connected:
- logger.log:
format: "API is connected"
level: INFO
# Enable Home Assistant API
api:
#port: 6053 # set port defaults to 6053
encryption:
key: !secret api_ecryption_key
reboot_timeout: 0s # default 15min
on_client_disconnected:
- logger.log: "API client disconnected!"
time:
- platform: homeassistant
ota:
password: !secret ota_password
# send log updates
on_state_change:
then:
- if:
condition:
lambda: return state == ota::OTA_STARTED;
then:
- logger.log: "OTA start"
- if:
condition:
lambda: return state == ota::OTA_IN_PROGRESS;
then:
- logger.log: "OTA_IN_PROGRESS"
- if:
condition:
lambda: return state == ota::OTA_COMPLETED;
then:
- logger.log: "OTA_COMPLETED"
- if:
condition:
lambda: return state == ota::OTA_ERROR;
then:
- logger.log: "OTA_ERROR"
on_error:
then:
- logger.log:
format: "OTA update error %d"
args: ["x"]
network:
enable_ipv6: False
wifi:
# use_address: !secret IP_adrress116
networks:
- ssid: !secret wifi_ssid
- ssid: !secret wifi_ssid2
password: !secret wifi_password2
manual_ip:
static_ip: !secret IP_address116
gateway: !secret IP_gateway
subnet: !secret IP_subnet
dns1: !secret IP_dns1
ap:
ssid: $devicename " Hotspot"
password: !secret wifi_AP_key
captive_portal:
web_server:
port: $web_port
version: 2
local: True
text_sensor:
- platform: wifi_info
ip_address:
name: ${devicename} IP Address
ssid:
name: ${devicename} Connected SSID
bssid:
name: ${devicename} Connected BSSID
mac_address:
name: ${devicename} Mac Wifi Address
# scan_results:
# name: ${devicename} Latest Scan Results
# control external relay switch (powersupplies)
power_supply:
# name: "power supply light 1"
- id: 'relayswitch1'
pin: $relaypin1
enable_time: 20ms
# name: "power supply light 2"
- id: relayswitch2
pin: $relaypin2
enable_time: 20ms
# name: "power supply light 3"
- id: relayswitch3
pin: $relaypin3
enable_time: 20ms
# name: "power supply light 4"
- id: relayswitch4
pin: $relaypin4
enable_time: 20ms
# display current PWM level (HA and webportal)
name: "light 1 (PWM level)"
lambda: |-
return id(light1setpercentpwm);
# update_interval: 10s
unit_of_measurement: "%"
accuracy_decimals: 1
icon: "mdi:pulse"
name: "light 2 (PWM level)"
lambda: |-
return id(light2setpercentpwm);
icon: "mdi:pulse"
# the switches we need
switch:
# (HA and webportal) restart ESP device button
- platform: restart
icon: "mdi:pulse"
# define 1st light (ha and esphome)
button:
name: "Main light 1 virtual-Button"
icon: "mdi:pulse"
on_press:
- lambda: |-
id(light1setpercentpwm)+ 10;
if( id(light1setpercentpwm) > 100 ) id(light1setpercentpwm) = 0;
id(light_1).set_level(id(light1setpercentpwm)/100);
id(light1setsensor).publish_state(id(light1setpercentpwm));
return id(light1setsensor).publish_state(id(light1setpercentpwm));
# define 2nd light (ha and esphome)
name: "Main light 2 virtual-Button"
icon: "mdi:pulse"
on_press:
- lambda: |-
id(light2setpercentpwm)+ 10;
if( id(light2setpercentpwm) > 100 ) id(light2setpercentpwm) = 0;
id(light_2).set_level(id(light2setpercentpwm)/100);
id(light2setsensor).publish_state(id(light2setpercentpwm));
return id(light2setsensor).publish_state(id(light2setpercentpwm));
# define the main light switch (ha and esphome + physical)
number:
name: "Main light group (1+2)"
step: 1
min_value: 0
max_value: 100
mode: slider
set_action:
then:
- lambda: |-
id(light1setpercentpwm) = x;
'return "bla" + id(light1setsensor).state id(light1setpercentpwm).value';
id(light2setpercentpwm) = x;
'return "bla" + id(light2setsensor) = id(light2setpercentpwm)';
name: "Main light 1"
step: 10
min_value: 0
max_value: 100
mode: slider
set_action:
then:
- lambda: |-
name: "Main light 2"
step: 10
min_value: 0
max_value: 100
mode: slider
set_action:
then:
- lambda: |-
'return id(light2setsensor) = id(light2setpercentpwm)';
binary_sensor:
- platform: gpio
name: "ESP32 Touch Pad" # physical touch-sensor (ts223)
pin: $touchpin1
icon: "mdi:GestureTapButton"
on_click:
- min_length: 50ms
max_length: 350ms
then:
# turn on or off
- lambda: |-
if(id(mainclick).state){
id(mainclick).publish_state(false);
'return id(mainclick).state';
id(light_1).turn_off();
'return id(light_1).state';
id(light_2).turn_off();
'return id(light_2).state';
id(light_3).turn_off();
'return id(light_3).state';
id(light_4).turn_off();
return ;
} else {
id(mainclick).publish_state(true);
id(light_1).turn_on();
id(light_2).turn_on();
'return id(light_4).state';
- logger.log: "touchswitch Short Click state change"
- min_length: 100ms
then:
# stepping light +10%
- lambda: id(MainLightClick) + 10;
- logger.log: "touchswitch Long Clicked state change"
name: "Main Light Touch-Button"
icon: "mdi:pulse"
on_state:
# equalize the lights (highest % of light 1 or 2 will win & equalize to 10,20,30,40,50,60,70,90 or 100, turn light 3 and 4 off)
- lambda: |-
if(id(a1stLightClick) != id(MainLightClick));
id(a1stLightClick) = id(MainLightClick);
'return id(a1stLightClick) = id(MainLightClick)';
if( id(a2ndLightClick) != id(MainLightClick));
id(a2ndLightClick) = id(MainLightClick);
'return id(a2ndLightClick) = id(MainLightClick)';
- logger.log: "main light touch-button state changed"
output:
# name: "light_1 state"
- platform: ledc # for PWM control 0-10v
pin: $pwmpin1 # PWM Pin 0-10v
frequency: 1000 Hz # PWM Pin 0-10v between 1000 and 3000 hz
power_supply: relayswitch1
inverted: False
min_power: 0.00
max_power: 1.00
zero_means_zero: False
# name: "light_2 state"
- platform: ledc
pin: $pwmpin2
frequency: 1000 Hz
inverted: False
min_power: 0.00
max_power: 1.00
light:
- platform: fastled_clockless
name: "Hidden lights (3)"
power_supply: relayswitch3
restore_mode: ALWAYS_OFF
chipset: WS2812B
pin: $pwmpin3
num_leds: 8
rgb_order: GRB
name: "Hidden lights (4)"
power_supply: relayswitch4
chipset: WS2812B
pin: $pwmpin4
num_leds: 8
rgb_order: GRB
effects:
- addressable_rainbow:
name: Rainbow Effect With Custom Values
speed: 10
width: 100
- random:
name: "Slow Random Effect"
transition_length: 3s
update_interval: 3s
- random:
name: "Fast Random Effect"
transition_length: 2s
update_interval: 1s
- strobe:
colors:
- state: True
brightness: 100%
red: 100%
green: 0%
blue: 0%
duration: 10ms
- state: False
duration: 10ms
- state: True
brightness: 100%
red: 0%
green: 0%
blue: 100%
duration: 10ms
- state: False
duration: 10ms
