4x4 matrix keypad with ESP8266
Dear all,
I just started with Esphome and want to integrate a 4x4 matrix keypad.
So far the ESP8266 (nodemcu V3) is connected to Esphome, but I dont see any keys pressed in the log. Dont know if it is a configuration problem or a hardware problem.
my yaml is as follow
esphome:
  friendly_name: esphome-keypad
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "*"
ota:
  password: "*"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Keypad Fallback Hotspot"
    password: "zRphTnExtTJE"
captive_portal:
matrix_keypad:
  rows:
    - pin: D1
    - pin: D2
    - pin: D3
    - pin: D4
  columns:
    - pin: D5
    - pin: D6
    - pin: D7
    - pin: D8
  keys: "123A456B789C*0#D"
  has_diodes: false
key_collector:
  - id: pincode_reader
    source_id: mykeypad
#    min_length: 4
    max_length: 4
#    end_keys: "#"
#    end_key_required: true
#    back_keys: "*"
#    clear_keys: "C"
#    allowed_keys: "0123456789"
#    timeout: 5s
    on_progress:
      - logger.log:
          format: "input progress: '%s', started by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]
    on_result:
      - logger.log:
          format: "input result: '%s', started by '%c', ended by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]
      - text_sensor.template.publish:
          state: !lambda "return x.c_str();"
    on_timeout:
      - logger.log:
          format: "input timeout: '%s', started by '%c'"
text_sensor:
Log
[23:05:38][I][app:102]: ESPHome version 2023.12.9 compiled on Jan 29 2024, 23:02:50
[23:05:38][C][wifi:573]: WiFi:
[23:05:38][C][wifi:405]:   Local MAC: *
[23:05:38][C][wifi:410]:   SSID: [redacted]
[23:05:38][C][wifi:411]:   IP Address: 192.168.178.225
[23:05:38][C][wifi:412]:   BSSID: [redacted]
[23:05:38][C][wifi:414]:   Hostname: 'esphome-keypad'
[23:05:38][C][wifi:416]:   Signal strength: -56 dB ▂▄▆█
[23:05:38][C][wifi:420]:   Channel: 11
[23:05:38][C][wifi:421]:   Subnet: 255.255.255.0
[23:05:38][C][wifi:422]:   Gateway: 192.168.178.1
[23:05:38][C][wifi:423]:   DNS1: 192.168.178.128
[23:05:38][C][wifi:424]:   DNS2: 0.0.0.0
[23:05:38][C][logger:439]: Logger:
[23:05:38][C][logger:440]:   Level: DEBUG
[23:05:38][C][logger:441]:   Log Baud Rate: 115200
[23:05:38][C][logger:443]:   Hardware UART: UART0
[23:05:38][C][template.text_sensor:020]: Template Sensor 'Keypad Code'
[23:05:38][C][matrix_keypad:095]: Matrix Keypad:
[23:05:38][C][matrix_keypad:096]:  Rows:
[23:05:38][C][matrix_keypad:098]:   Pin: GPIO5
[23:05:38][C][matrix_keypad:098]:   Pin: GPIO4
[23:05:38][C][matrix_keypad:098]:   Pin: GPIO0
[23:05:39][C][matrix_keypad:098]:   Pin: GPIO2
[23:05:39][C][matrix_keypad:100]:  Cols:
[23:05:39][C][matrix_keypad:102]:   Pin: GPIO14
[23:05:39][C][matrix_keypad:102]:   Pin: GPIO12
[23:05:39][C][matrix_keypad:102]:   Pin: GPIO13
[23:05:39][C][matrix_keypad:102]:   Pin: GPIO15
[23:05:39][C][key_collector:023]: Key Collector:
[23:05:39][C][key_collector:027]:   max length: 4
[23:05:39][C][captive_portal:088]: Captive Portal:
[23:05:39][C][mdns:115]: mDNS:
[23:05:39][C][mdns:116]:   Hostname: esphome-keypad
[23:05:39][C][ota:097]: Over-The-Air Updates:
[23:05:39][C][ota:098]:   Address: esphome-keypad.local:8266
[23:05:39][C][ota:101]:   Using Password.
[23:05:39][C][api:139]: API Server:
[23:05:39][C][api:140]:   Address: esphome-keypad.local:6053
[23:05:39][C][api:142]:   Using noise encryption: YES
[23:08:18][I][ota:117]: Boot seems successful, resetting boot loop counter.
This is the keypad
I connected from the left to the right
D1 to D8
like the pad on the right
not sure if it is 100% correct, but at least is should see some output even it is the wrong key.
Any ideas ?
I have read that using D8 for keypad input can be problematic - to the point where it may be easier to use D0…
Also - an ESP8266 is not a great choice for a 4x4 keypad, you pretty well run out of pins straight away - nothing left for anything else.
This note is towards the end on this page:
Thx for your answer.
I changed D8 to D0 and now it is working.
  rows:
    - pin: D1
    - pin: D2
    - pin: D3
    - pin: D4
  columns:
    - pin: D5
    - pin: D6
    - pin: D7
    - pin: D8
