I looked through the posts for number of these and can’t find the same issue, (maybe it is there)
I have AdGuard, DuckDNS, Configurator, Terminal installed
If I connect from outside my house (using https://mydomain.duckdns.org:8123
l can login, see all the dashboard OK, see the log and history
If I try from the left hand mane to get Configurator, AdGuard or Terminal I get
500 Internal Server Error
Server got itself in trouble
However if I connect the same way but through the Home-Assistant app on my phone these addons render perfectly well.
If I connect internally via a browser (via 192.168.1.x:8123) it works fine.
Happy to provide a log - there is nothing unusual in home-assistant.log, is there an easy way to pick up any other logs that might help?
Additional:
If I go in through Hass.io, click the addon, then in addon details click Open Web UI I get the error:
401: Unauthorized
