First post here, please don’t flame if i’m missing some info…
I’m trying to set up the Alexa smart home skill, and couldn’t get past the 401 errors when not supplying a long lived access token. So i generated one, passed it to my lambda function, and now I get a 500 RC, “Server got itself in trouble”
So I took a few steps back, and wrote some code to test the API locally. My instance is running via nginx reverse proxy, with 443 fwd’ed to 8123, and letsencrypt for ssl. So I start testing using the local hostname:8123 and NO_VERIFY_SSL, and get the same results.
When using PUT and URI = <home assistant>/api/ i get API running while supplying a header containing a valid token. Change the token and i’m getting a 401. So we know that token auth is working. When I invoke PUT against .../api/states i get a list of all the the entities and their states (also fails with a bad token).
But when I run a GET against .../api/alexa i get 405: Method Not Allowed – using POST (which is what the lambda function is using in the instructions, per matt2005) i get 500 Internal Server Error Server got itself in trouble
HA logs show a bunch of fails, including:
[homeassistant.components.alexa.auth] Token invalid and no refresh token available
and
ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 125, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/alexa/intent.py", line 56, in post
message = await request.json()
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_request.py", line 584, in json
return loads(body)
File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
There’s a bunch of other logs that seem to show that HA is trying to send change reports (don’t know what this means, really)
[homeassistant.components.alexa.state_report] Sent: {"event": {"header": {"namespace": "Alexa", "name": "ChangeReport", "messageId": "d3ba4440-ed9d-463b-86b7-314fa99b7464", "payloadVersion": "3"}, "payload": {"change": {"cause": {"type": "APP_INTERACTION"}, "properties": [{"name": "connectivity", "namespace": "Alexa.EndpointHealth", "value": {"value": "OK"}, "timeOfSample": "2020-04-27T04:53:28.0Z", "uncertaintyInMilliseconds": 0}]}}, "endpoint": {"scope": {"type": "BearerToken", "token": null}, "endpointId": "camera#radar_new_york_animated"}}}
I’m probably missing something silly, but looking for any advice that I can get.
