502: Bad Gateway
Hi All, anyone an idee why I get the following error. I am already trying to fix for 2 days without success.
Want to connect with Zigbee2mqtt
502: Bad Gateway
Configuration
data_path: /config/zigbee2mqtt
external_converters:
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto
user: mqtt_user
password: mqtt_password
serial:
port: /dev/ttyUSB0
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
1
3
5
7
9
11
13
15
0
2
4
6
8
10
12
13
availability_blocklist:
availability_passlist:
device_options: {}
blocklist:
passlist:
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: ‘-d -d’
log: false
Log:
[email protected] start > node index.js Zigbee2MQTT:error 2022-03-13 16:46:23: Error while starting zigbee-herdsman Zigbee2MQTT:error 2022-03-13 16:46:23: Failed to start zigbee Zigbee2MQTT:error 2022-03-13 16:46:23: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions Zigbee2MQTT:error 2022-03-13 16:46:23: Exiting… Zigbee2MQTT:error 2022-03-13 16:46:24: TypeError: Cannot read property ‘length’ of null at AdapterNvMemory.init (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:28:42) at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:60:9) at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29) at Zigbee.start (/app/lib/zigbee.ts:58:27) at Controller.start (/app/lib/controller.ts:100:27) at start (/app/index.js:101:5) [16:46:24] INFO: Handing over control to Zigbee2mqtt Core … > [email protected] start > node index.js
00
Comments
Share
Save
