yes wrote message and i changed the ssl to flase this is my new config plus log from the add on…
This is my config
“credential_secret”: “”,
“dark_mode”: false,
“http_node”: {
“username”: “”,
“password”: “”
“http_static”: {
“username”: “”,
“password”: “”
“ssl”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“require_ssl”: false,
“system_packages”: [],
“npm_packages”: [],
“init_commands”: []
LOG NODE RED
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Hass.io Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 4.2.1
You are running the latest version of this add-on.
System: HassOS 2.12 (armv7 / raspberrypi3)
Home Assistant version: 0.99.3
Supervisor version: 189
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[11:15:21] FATAL:
[11:15:21] FATAL: SSL has been enabled using the ‘ssl’ option,
[11:15:21] FATAL: this requires a SSL certificate file which is
[11:15:21] FATAL: configured using the ‘certfile’ option in the
[11:15:21] FATAL: add-on configuration.
[11:15:21] FATAL:
[11:15:21] FATAL: Unfortunately, the file specified in the
[11:15:21] FATAL: ‘certfile’ option does not exists.
[11:15:21] FATAL:
[11:15:21] FATAL: Please ensure the certificate file exists and
[11:15:21] FATAL: is placed in the Hass.io ‘/ssl/’ directory.
[11:15:21] FATAL:
[11:15:21] FATAL: In case you don’t have SSL yet, consider getting
[11:15:21] FATAL: a SSL certificate or setting the ‘ssl’ option
[11:15:21] FATAL: to ‘false’ in case you are not planning on using
[11:15:21] FATAL: SSL with this add-on.
[11:15:21] FATAL:
[11:15:21] FATAL: Check the add-on manual for more information.
[11:15:21] FATAL:
[cont-init.d] nginx.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
