hi all
just installed node red from the addons section
but get 502: Bad Gateway when launching the UI any ideas ?
thanks Arden
hi all
thanks Arden
Same here:
Having same issue:
5 Jun 11:13:43 - [info] Started flows
5 Jun 11:13:43 - [red] Uncaught Exception:
5 Jun 11:13:43 - Error: connect ECONNRESET 192.168.1.50:4025
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1117:14)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! hassio-addon-node-red@ start: `node $NODE_OPTIONS node_modules/node-red/red.js "--settings" "/etc/node-red/config.js"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the hassio-addon-node-red@ start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2019-06-05T16_13_43_528Z-debug.log
I’ve just updated Node Red and now I’m getting Bad Gateway. Bad update?
Any help appreciated.
Pretty sure when I got that message I just went into HA and created a new authorization token. Then in NR I re-entered the HA server information using the new token.
Thanks, I’ll try that.
