Dear,
I got HASS running on a VM on my unraid server (see setup below)
All is working fine localy, however when i want to acces my HASS throughout my custom domain (like nabu casa) it connects for 20 seconds and then gives a timeout and a 502 error.
I connect it throughout a reverse proxy (Swag → Letsencrypt) that has an Nginx server running.
All the other apps i use with this setup have no isue’s so far. Anyone got an idea how i could debug this or what the problem could be ?
See the setup and settings below.
Firewall portforward:
VM Setup in Unraid
For security reasons i’ve set my domain to xxx.xx (not gonne give away my real domain) ^^
HASS config concerning the HTTP stuff
## HASS Default settings ##
homeassistant:
external_url: "https://homeassistant.xxx.xx"
internal_url: "http://homeassistant.local:8123"
latitude: !secret homeassistant_latitude
longitude: !secret homeassistant_longitude
elevation: !secret homeassistant_elevation
unit_system: metric
temperature_unit: C
time_zone: Europe/Brussels
currency: EUR
packages: !include_dir_named include
allowlist_external_dirs: [/config/]
media_dirs:
local: /media
## HTTP ##
http:
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
- https://homeassistant.xxx.xx
use_x_forwarded_for: true
trusted_proxies:
- 192.168.0.2
- 192.168.0.130
- 172.0.0.1
ip_ban_enabled: true
login_attempts_threshold: 5
SWAG proxy config for the reverse proxy
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name homeassistant.*;
include /config/nginx/ssl.conf;
client_max_body_size 0;
location / {
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
include /config/nginx/proxy.conf;
include /config/nginx/resolver.conf;
set $upstream_app 192.168.0.130;
set $upstream_port 8123;
set $upstream_proto http;
proxy_pass $upstream_proto://$upstream_app:$upstream_port;
location /api {
location /local {
If you need more info feel free to ask, thanks in advance!
