I hava mosquito and zigbee2mqtt installed, and sonoff hw coordinator,
My logs are in zigbee2mqtt component:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] socat.sh: executing…
[18:42:21] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing…
[18:42:22] INFO: MQTT available, fetching server detail …
[18:42:22] INFO: MQTT server settings not configured, trying to auto-discovering …
[18:42:23] INFO: Configuring ‘mqtt://core-mosquitto:1883’ mqtt server
[18:42:24] INFO: MQTT credentials not configured, trying to auto-discovering …
[18:42:24] INFO: Configuring’addons’ mqtt user
[18:42:24] INFO: Previous config file found, checking backup
[18:42:24] INFO: Creating backup config in ‘/config/zigbee2mqtt/.configuration.yaml.bk’
[18:42:24] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks …
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[18:42:26] INFO: Handing over control to Zigbee2mqtt Core …
[email protected] start /app
node index.js
Zigbee2MQTT:error 2022-02-04 18:42:50: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-02-04 18:42:50: Failed to start zigbee
Zigbee2MQTT:error 2022-02-04 18:42:50: Exiting…
Zigbee2MQTT:error 2022-02-04 18:42:50: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter. (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
at Generator.throw ()
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start:node index.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-02-04T17_42_51_024Z-debug.log
Any suggestion ?
