59.1 breaks amcrest camera
My amcrest cameras worked fine with 58. Upgraded to 59.1 and now getting following error.
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 193, in _async_setup_component
component.setup, hass, processed_config)
File “/usr/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/amcrest.py”, line 93, in setup
amcrest_cams = config[DOMAIN]
KeyError: ‘amcrest’
2017-12-05 20:16:34 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of camera.amcrest. Setup failed for dependencies: amcrest
2017-12-05 20:16:34 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform camera.amcrest: Could not setup all dependencies.
Any help appreciated.
There was a change to armcrest in 0.59
you may need to reconfirm config for armcrest
I am running 4 Amcrest Cameras, and I upgraded to 59.1 without any issues.
But, now I get the message stating;
Setup of amcrest is taking over 10 seconds.
11:59 AM bootstrap.py (WARNING)
which I never got before…
I had this in my configuration prior to 59.1
resolution: low
stream_source: snapshot
Switched to
resolution: high
stream_source: rtsp
Resolved issue. I also have seen warning message occasionally prior to 59.1
