5G Tuya Door Eye Hole Security 1080P
Hello, I have been using this camera for peephole surveillance and recording for a while now. I’m a new Home Assistant user and I want my camera to be available in the Control Panel with WebRTC without lag. I even want to see the live broadcast as a pop-up screen in the Control panel when motion is detected. But no matter what I tried, it didn’t quite work. Is there a user who can guide me on this issue, or rather explain the solution as if explaining it to a stone? (There is no tab to activate the ONvif feature in the Tuya smart application. However, it is written on the camera purchase page that there is Onvif support.) In Tuya smart, the device IP address appears as 192.168.2.x.
Did you find the onvif settings already. Just can tell you that tuya seems to be possible to enable it like that:
When you enabled this, just use:
