Hi all, I’ve a bunch of LED strips to install and trying to decide between CCT and RGBCCT ones. The most often recommended here - the Gledopto ones - are a bad choice for me because they can only be cut every 50cm.
Having browsed AliExpress a lot, I saw these 5in1 ones, where each of the LED packages has all the 5 channels, and can be cut every 28mm, allowing for precise fitting:
Has anyone had any experience with those? It looks like the RGB ones are smaller than normal, but then they’re packed more densely. OTOH I couldn’t find specs on the power they run, or how do they compare in brightness with regular RGBCCT.
Thanks!
