Most of the errors are the following repeated over and over and over again:
2020-02-14 13:17:46 ERROR (Recorder) [homeassistant.components.recorder] Error saving event: <Event service_registered[L]: domain=recorder, service=purge>
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1246, in _execute_context
cursor, statement, parameters, context
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/default.py", line 588, in do_execute
cursor.execute(statement, parameters)
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 348, in run
session.flush()
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2479, in flush
self._flush(objects)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2617, in _flush
transaction.rollback(_capture_exception=True)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/langhelpers.py", line 68, in __exit__
compat.reraise(exc_type, exc_value, exc_tb)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 153, in reraise
raise value
Any idea how to fix this?
Everything seems to be working just fine otherwise.
