6.12.23-haos usb_snd_audio
6.12.23-haos does not have kernel modules for my usb audio support.
I’m using a asus laptop with an N6000 pentium processor as the HA server.
I’m using a usb speaker / microphone attached to said laptop and it is listed under lsusb but arecord does not recognize it which I believe is why my voice assist does not work. Using lsusb I get “Bus 001 Device 010: ID 1234:5684 MV-SILICON P10S” among other devices. I can select “P10S” in the assist microphone addon configuration. But it will not respond to wake word.
Surely I’m not the only one with this problem.
Hello Scott McBride.
You are likely correct.
Or any audio support.
I used an home assistant image file to install which uses docker containers. Is there an addon like assist microphone that could load the necessary modules to give me the functions I need drive the microphone and speaker?
If you installed with Docker, then you have to find Dockers not add-ons to exten HA functions.
Aside from that, generally the microphone and voice stuff is in other devices, like HA’s VPE, a Google hub, Alexa device, home brew esphome, something like that.
My HA server, which is an old Asus laptop, isn’t recognizing my USB speaker and mic, even though I can see it listed. I think it’s because it’s missing some special software, and that’s why my voice assistant won’t work. I really hope I’m not the only one dealing with this!
