I recently purchased a smart switch / energy meter - with the main intent of using it to read the energy data.
It integrates using the eWelink smart home Add-on - which displays the power consumption, etc on the add-on screen.
However the add-on only exposes the Switch to Home Assistant - and I can’t seem to get to the power consumption values - to add them to a Home assistant dashboard, etc
Thanks - I already have the eWelink Smart Home integration installed - but did so via the standard HA integration options. I could not find a ewelink via the HACS integrations?
I only get the switch as an entity - there is no entities for voltage and amperage?
Did you apply a specific config in the configuration,yaml file?
I managed to see my wifi Power meter to Home Assistant. I want to see a day graph like yours here about max and min power consuption. How did you set the Homme assistance to see the energy meter. i cant find the way.
Looks like I cant get my power monitoring switches to show energy monitoring too, not on HA neither in ewelink app. Manufacturer says to hook them up through Tuya, but thats going to meessup my HA as all zigbee devices already hookedup using ewelink
I’m in the process of purchasing a similar energy meter which connects through the eWelink app. I want to add the power readings into HA for switching on and off various other Sonoff devices, based on load.
Just a question to you guys who already have them installed, what is the update frequency of the meter? Every second? Every 5 seconds?
