yah, I repasted the file so that the spaces were gone.
I would suggest trying to load the dark sky sensor component directly in your configuration.yaml file and paste the api key directly in there as well, and use that as a starting point to see if you are still getting the error.
I have had both the DarkSky sensor and Platform working, currently they are commented out to eliminate any potential conflicts.
edit: I just went back and re-enabled the Darksky sensor entry and it pulled the data as needed.
The Darksky platform worked as well when I re-enabled it.
I donât understand the key error.
From google searches it seems the required key not provided is a vague error that isnât related to the darksky api key.
Iâve seen entries for switches, sensors, automations, MQTT, and more.
Iâve also been reading the docs on packages Packages - Home Assistant and it references âkeys representing the filenamesâ.
So outside of packages:
!include_dir_named packages
in the configuration.yaml does there need to be any other entry or am I misunderstanding the keys thing?
Hello Iâm trying to install and copy the two directories from github to my hassio config, add two line in my configuration.yaml and when check if configuration is valid I obtain yhis :extra keys not allowed @ data[âpython_scriptâ]. I have 0.80.2 version.
that would be an indentation error. Check that you have 2 spaces where required
Verify youâve read through the post and are using the latest code. You shouldnât need to use the python script to update the friendly names, you can do this with friendly name templating.
As of version 0.81:
Template sensors will no longer auto update if we canât find relevant entities in the template. Youâll want to review your template sensors and consider adding relevant entity_id
entries or use the new homeassistant.update_entity
service.
Adding entity_id
to every template sensor seemed clunky, so this automation is what I added in my weather.yaml package:
automation:
- alias: Update Sensors
initial_state: on
platform: time
hours: '/3'
minutes: 01
seconds: 00
service: homeassistant.update_entity
entity_id:
- sensor.weekday
- sensor.forecast_today
- sensor.forecast_1
- sensor.forecast_2
- sensor.forecast_3
- sensor.forecast_4
- sensor.forecast_5
- sensor.forecast_6
- sensor.forecast_7
This will update all weather sensors every 3 hours. Seems to be working fine. Please note that you must be on v0.81.1 or later. v0.81.0 did not allow the use of a list for the service data for homeassistant.update_entity
Wonât that still give an error in the log when HA starts up?
I added the entity idâs to all my templates⊠there were only 7 to add and copy/paste made it pretty simple.
What did you enter for the entity_idâs?
Here is an example of the first forcast for me.
forecast_1:
friendly_name_template: >
{%- set date = as_timestamp(now()) + (1 * 86400 ) -%}
{{ date | timestamp_custom("Tomorrow (%m/%d)") | replace("(0", "(") | replace("/0", "/") }}
value_template: >
{{states.sensor.dark_sky_daytime_high_temperature_1.state|round(0)}}/{{states.sensor.dark_sky_overnight_low_temperature_1.state|round(0)}}/{{states.sensor.dark_sky_precip_probability_1.state|round(0)}}%
entity_picture_template: >-
{{ '/local/icons/dark_sky/' ~ states.sensor.dark_sky_icon_1.state ~ '.png'}}
entity_id: sensor.dark_sky_daytime_high_temperature_1, sensor.dark_sky_overnight_low_temperature_1, sensor.dark_sky_precip_probability_1
Oh, I understand now. You use the entity_id the value_template is based on. I was confused as to what should be used. That clears it up, thank you.
I just updated to the latest package and receive this error for every forcast
2018-12-19 20:13:17 WARNING (MainThread) [homeassistant.components.sensor.template] Template sensor forecast_1 has no entity ids configured to track nor were we able to extract the entities to track from the friendly_name template(s). This entity will only be able to be updated manually.
is that intentional? I can add the entity idâs and have no issue with doing so, just figure that since its not there, they might be a reason?
yes it was a breaking change a few versions ago. you need to add the entity_id to the sensor
Totally familiar with the breaking change. I updated today because of the day 0 addition. The git was just updated 25 days ago
https://github.com/arsaboo/homeassistant-config/blob/master/packages/weather.yaml
@arsaboo is such a key person Iâd assume the entity ids would be included which is why i asked if it was intentional
Iâll probably add the ids unless I hear otherwise.
adding the entity idâs is not the only way to solve the problem. You can also use an automation.
Thanks everyone for all your help here to get me up and running on this. I have a question, is there a way to convert the forecast card to an image file so I can sms/email etc it outside of HA?
My wife would love that if I could have it delivered to her phone.
Mike
I donât know of a way to do what youâre asking, not to say that it canât be done. How about just creating a view in hass with only the data you want her to see, navigate to that via Chrome on her device, and use âAdd to Homeâ to create an icon that leads directly to that page?
Thanks, will do it that way for now. Sill looking into it, thinking there may be a generic cam approach here.
