Could somebody help to kick me to the instruction how to describe in yaml the work with 74HC595 (I’m using it for control of 8 switchers) shift out register and 74HC165 (I’m using it for control of 8 buttons) shift in register?
Please do not suggest to use something another hardware. I’m already have the PCB and I want to work with it.
I did a custom component which does port expanding, so basically you have additional binary_sensors and outputs… you might want to check the ape.h (arduino port extender) here.
As the shifters are real world components, I believe they qualify for a bundled component on ESPHome. Please fill in a feature request so we can track this better.
@Andrew81 could you please share a little more about how you achieved this?
I’m looking at doing a project where I will need to address 30 mosfets - my wife saw that video on reddit where the stairs light up in sequence. My brain says this needs a bunch of shift registers, but, although I sort of understand in principle how that’s done, I’m a little wobbly on the actual implementation.
I looked at @glmnet’s code, but, I feel like if I could see how someone else actually implemented shift registers in ESPHome, it’d be a huge help.
Honestly I’m just trying to get to the point where each light strip is exposed as a switch, and I’ll do the rest of the jiggery pokery in node-RED.
If you have a moment, please share your yaml and .h file. Help an idiot out.
Hi @glmnet, in an ideal world, yes, addressable would be wonderful. No mosfets, and I would only have to work out how to keep 5V power stable to 15 strings.
But, I don’t have any addressable LEDs, and they are terrifyingly expensive in my country vs single colour 5050 LEDs (about 4 times more per m). Also, I already have plenty of single colour LEDs.
My approach to this project, therefore, was to just have 2 colours: warm white for when people are awake, and red for night time. That way I don’t need to work out how to send colour data to 15 individual stairs, I just have to switch on and off 2 strings per stair (white or red). Easier than RGB data, which would have required 3 mosfets per stair, and 45 actual GPIOs, since I can’t think of a way to send more complex data than ON/OFF via shift register. It’s of course very likely that I just don’t understand shift registers very well.
So my approach will need “only” 2 mosfets per stair, but a lot of shift registers to address all 30 mosfets.
You can’t do PWM on the 74HC595 (sorry I assume this is an output shift register)
In any case you can go with the https://esphome.io/components/output/pca9685.html
We should add support for the output shift register anyway but I believe PWM will make it WOW better and those are cheap and already implemented.
#include "esphome.h"
// global variable to store state of bits
byte rele_state = 0;
// pins of the shift register (74HC595)
const byte outputLatch_pin = D1;
const byte clock_pin = D5;
const byte mosi_pin = D7;
class binSwitch : public Component, public Switch
byte pinNum;
bool SetBit(bool pinValue, byte number)
if (pinValue)
bitSet(rele_state, number);
else
bitClear(rele_state, number);
SetRele();
return pinValue;
void SetRele()
digitalWrite(clock_pin, LOW);
digitalWrite(outputLatch_pin, LOW);
shiftOut(mosi_pin, clock_pin, LSBFIRST, rele_state);
digitalWrite(outputLatch_pin, HIGH);
public:
// pin - output pin of the shift register (0..7)
binSwitch(byte pin) { pinNum = pin; }
void setup() override
pinMode(outputLatch_pin, OUTPUT);
pinMode(clock_pin, OUTPUT);
pinMode(mosi_pin, OUTPUT);
SetRele();
void write_state(bool state) override
publish_state(SetBit(state, pinNum));
yml file
esphome:
platform: ESP8266
board: nodemcuv2
includes:
- binSwitch.h
switch:
- platform: custom
lambda: |-
auto switch1 = new binSwitch(0);
auto switch2 = new binSwitch(1);
auto switch3 = new binSwitch(2);
auto switch4 = new binSwitch(3);
auto switch5 = new binSwitch(4);
auto switch6 = new binSwitch(5);
auto switch7 = new binSwitch(6);
auto switch8 = new binSwitch(7);
App.register_component(switch1);
App.register_component(switch2);
App.register_component(switch3);
App.register_component(switch4);
App.register_component(switch5);
App.register_component(switch6);
App.register_component(switch7);
App.register_component(switch8);
return {switch1,switch2,switch3,switch4,switch5,switch6,switch7,switch8};
switches:
- name: "Refrigerator Switch 1"
- name: "Refrigerator Switch 2"
- name: "Refrigerator Switch 3"
- name: "Refrigerator Switch 4"
- name: "Refrigerator Switch 5"
- name: "Refrigerator Switch 6"
- name: "Refrigerator Switch 7"
- name: "Refrigerator Switch 8"
I hope this will be helpful for you. Feel free to contact me for any future questions.
Note: shift registers can be merged to a group and in this case you should use an array instead of byte global variable and change logic to push states to the register.
@glmnet, I think that currently my code is unusable for a public component. Idealy need to support group of registers. I will learn how been realized current components and will prepare the ready component, but neeed more tme for this
Hi @Andrew81 - thank you so much for posting this. Right now I’m reading it and going, “uhhhhhh …”, but I can sort of see what’s up. This is a backburner project for me; my main focus is preventing our farm from dying of drought (ESPHome + flowmeters is rocking for this), but, glowing stairs are important, too.
Hi @glmnet, you’re correct, I’m thinking of an output shift register.
However, I’m not thinking of sending any sort of brightness data, so I didn’t think PWM was necessary. Surely if I’m just trying to turn on a string of LEDs, I don’t need PWM?
Please correct me if I’m wrong. I’m used to being wrong. It’s how I learn.
Ahh yes, of course you don’t need PWM to turn on LEDs 100% on, 100% off, but hey!, if you have a IC controlling the output and driving the LEDs with a mosfet the only reason you’ll not be able to do PWM will be the shift register and there are other not so expensive options so this was just a question/recommendation. With two PCA9685 you can drive 32 mosfets on a single i2c bus.
It’ll be nice to have the 74HC595 supported in the core.
