Finally it works!
Here is my conf for using 32Bit Outputs and 32BitInputs, using 4x74HC595 and 4x74HC165
Because of the channel-numbering (it used to start with 0, i want it to start with 1) i made a little change with the Clock toggeling.
Binswitch.h (for 74HC595):
#include "esphome.h"
// global variable to store state of bits
uint64_t output_state = 0;
// pins of the Output shift register (74HC595)
const byte outputLatch_pin = 15;
const byte clock_pin = 14;
const byte mosi_pin = 13;
class binSwitch : public Component, public Switch
byte pinNum;
bool SetBit(bool pinValue, uint64_t number)
if (pinValue)
bitSet(output_state, number);
else
bitClear(output_state, number);
SetOutputs();
return pinValue;
void SetOutputs()
digitalWrite(clock_pin, LOW);
digitalWrite(outputLatch_pin, LOW);
shiftOut(mosi_pin, clock_pin, LSBFIRST, output_state);
shiftOut(mosi_pin, clock_pin, LSBFIRST, output_state >> 8);
shiftOut(mosi_pin, clock_pin, LSBFIRST, output_state >> 16);
shiftOut(mosi_pin, clock_pin, LSBFIRST, output_state >> 24);
digitalWrite(outputLatch_pin, HIGH);
public:
// pin - output pin of the shift register (0..31)
binSwitch(byte pin) { pinNum = pin; publish_state(false);}
void setup() override
pinMode(outputLatch_pin, OUTPUT);
pinMode(clock_pin, OUTPUT);
pinMode(mosi_pin, OUTPUT);
SetOutputs();
void write_state(bool state) override
publish_state(SetBit(state, pinNum));
and 74HC165.h:
class SN74HC165Component : public PollingComponent, public BinarySensor
byte pinNum;
private:
const byte LATCH = 4; // ESP pin number that should be connected to pin 1 of 74hc165s
const byte DATA = 5; // ESP pin number that should be connected to pin 9 of first 74hc165
const byte CLOCK = 2; // ESP pin number that should be connected to pin 2 of 74hc165s
bool getBit(unsigned long x, byte n)
bool value = bitRead(x, n);
return value;
unsigned long shiftinput= 1;
unsigned long oldshiftinput= 0;
public:
SN74HC165Component (byte pin) : PollingComponent(100) { pinNum = pin; } // Change the number inside "PollingComponent(100)" to change update interval in miliseconds
float get_setup_priority() const override { return esphome::setup_priority::HARDWARE; }
pinMode(LATCH, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(DATA, INPUT);
digitalWrite(CLOCK, LOW);
digitalWrite(CLOCK, HIGH);
digitalWrite(LATCH, HIGH);
void update() override
digitalWrite(LATCH, LOW);
shiftinput = shiftIn(DATA, CLOCK, LSBFIRST);
shiftinput |= shiftIn(DATA, CLOCK, LSBFIRST) << 8;
shiftinput |= shiftIn(DATA, CLOCK, LSBFIRST) << 16;
shiftinput |= shiftIn(DATA, CLOCK, LSBFIRST) << 24;
if (shiftinput != oldshiftinput)
publish_state(getBit(shiftinput, pinNum));
oldshiftinput = shiftinput;
and here the ESPhome yaml:
esphome:
platform: ESP8266
board: d1_mini
includes:
- binSwitch.h
- 74HC165.h
wifi:
ssid: "yourSSID"
password: "yourPW"
manual_ip:
static_ip: 192.168.2.244
gateway: 192.168.2.1
subnet: 255.255.252.0
# Enable Home Assistant API
api:
password: "yourPW"
ota:
password: "yourPW"
web_server:
port: 80
switch:
- platform: custom
lambda: |-
auto switch1 = new binSwitch(0);
auto switch2 = new binSwitch(1);
auto switch3 = new binSwitch(2);
auto switch4 = new binSwitch(3);
auto switch5 = new binSwitch(4);
auto switch6 = new binSwitch(5);
auto switch7 = new binSwitch(6);
auto switch8 = new binSwitch(7);
auto switch9 = new binSwitch(8);
auto switch10 = new binSwitch(9);
auto switch11 = new binSwitch(10);
auto switch12 = new binSwitch(11);
auto switch13 = new binSwitch(12);
auto switch14 = new binSwitch(13);
auto switch15 = new binSwitch(14);
auto switch16 = new binSwitch(15);
auto switch17 = new binSwitch(16);
auto switch18 = new binSwitch(17);
auto switch19 = new binSwitch(18);
auto switch20 = new binSwitch(19);
auto switch21 = new binSwitch(20);
auto switch22 = new binSwitch(21);
auto switch23 = new binSwitch(22);
auto switch24 = new binSwitch(23);
auto switch25 = new binSwitch(24);
auto switch26 = new binSwitch(25);
auto switch27 = new binSwitch(26);
auto switch28 = new binSwitch(27);
auto switch29 = new binSwitch(28);
auto switch30 = new binSwitch(29);
auto switch31 = new binSwitch(30);
auto switch32 = new binSwitch(31);
App.register_component(switch1);
App.register_component(switch2);
App.register_component(switch3);
App.register_component(switch4);
App.register_component(switch5);
App.register_component(switch6);
App.register_component(switch7);
App.register_component(switch8);
App.register_component(switch9);
App.register_component(switch10);
App.register_component(switch11);
App.register_component(switch12);
App.register_component(switch13);
App.register_component(switch14);
App.register_component(switch15);
App.register_component(switch16);
App.register_component(switch17);
App.register_component(switch18);
App.register_component(switch19);
App.register_component(switch20);
App.register_component(switch21);
App.register_component(switch22);
App.register_component(switch23);
App.register_component(switch24);
App.register_component(switch25);
App.register_component(switch26);
App.register_component(switch27);
App.register_component(switch28);
App.register_component(switch29);
App.register_component(switch30);
App.register_component(switch31);
App.register_component(switch32);
return {switch1,switch2,switch3,switch4,switch5,switch6,switch7,switch8,switch9,switch10,switch11,switch12,switch13,switch14,switch15,switch16,switch17,switch18,switch19,switch20,switch21,switch22,switch23,switch24,switch25,switch26,switch27,switch28,switch29,switch30,switch31,switch32};
switches:
- name: "Switch 1"
- name: "Switch 2"
- name: "Switch 3"
- name: "Switch 4"
- name: "Switch 5"
- name: "Switch 6"
- name: "Switch 7"
- name: "Switch 8"
- name: "Switch 9"
- name: "Switch 10"
- name: "Switch 11"
- name: "Switch 12"
- name: "Switch 13"
- name: "Switch 14"
- name: "Switch 15"
- name: "Switch 16"
- name: "Switch 17"
- name: "Switch 18"
- name: "Switch 19"
- name: "Switch 20"
- name: "Switch 21"
- name: "Switch 22"
- name: "Switch 23"
- name: "Switch 24"
- name: "Switch 25"
- name: "Switch 26"
- name: "Switch 27"
- name: "Switch 28"
- name: "Switch 29"
- name: "Switch 30"
- name: "Switch 31"
- name: "Switch 32"
binary_sensor:
- platform: custom
lambda: |-
auto X01 = new SN74HC165Component(0);
auto X02 = new SN74HC165Component(1);
auto X03 = new SN74HC165Component(2);
auto X04 = new SN74HC165Component(3);
auto X05 = new SN74HC165Component(4);
auto X06 = new SN74HC165Component(5);
auto X07 = new SN74HC165Component(6);
auto X08 = new SN74HC165Component(7);
auto X09 = new SN74HC165Component(8);
auto X10 = new SN74HC165Component(9);
auto X11 = new SN74HC165Component(10);
auto X12 = new SN74HC165Component(11);
auto X13 = new SN74HC165Component(12);
auto X14 = new SN74HC165Component(13);
auto X15 = new SN74HC165Component(14);
auto X16 = new SN74HC165Component(15);
auto X17 = new SN74HC165Component(16);
auto X18 = new SN74HC165Component(17);
auto X19 = new SN74HC165Component(18);
auto X20 = new SN74HC165Component(19);
auto X21 = new SN74HC165Component(20);
auto X22 = new SN74HC165Component(21);
auto X23 = new SN74HC165Component(22);
auto X24 = new SN74HC165Component(23);
auto X25 = new SN74HC165Component(24);
auto X26 = new SN74HC165Component(25);
auto X27 = new SN74HC165Component(26);
auto X28 = new SN74HC165Component(27);
auto X29 = new SN74HC165Component(28);
auto X30 = new SN74HC165Component(29);
auto X31 = new SN74HC165Component(30);
auto X32 = new SN74HC165Component(31);
App.register_component(X01);
App.register_component(X02);
App.register_component(X03);
App.register_component(X04);
App.register_component(X05);
App.register_component(X06);
App.register_component(X07);
App.register_component(X08);
App.register_component(X09);
App.register_component(X10);
App.register_component(X11);
App.register_component(X12);
App.register_component(X13);
App.register_component(X14);
App.register_component(X15);
App.register_component(X16);
App.register_component(X17);
App.register_component(X18);
App.register_component(X19);
App.register_component(X20);
App.register_component(X21);
App.register_component(X22);
App.register_component(X23);
App.register_component(X24);
App.register_component(X25);
App.register_component(X26);
App.register_component(X27);
App.register_component(X28);
App.register_component(X29);
App.register_component(X30);
App.register_component(X31);
App.register_component(X32);
return {X01,X02,X03,X04,X05,X06,X07,X08,X09,X10,X11,X12,X13,X14,X15,X16,X17,X18,X19,X20,X21,X22,X23,X24,X25,X26,X27,X28,X29,X30,X31,X32};
binary_sensors:
- name: "Input 1"
- name: "Input 2"
- name: "Input 3"
- name: "Input 4"
- name: "Input 5"
- name: "Input 6"
- name: "Input 7"
- name: "Input 8"
- name: "Input 9"
- name: "Input 10"
- name: "Input 11"
- name: "Input 12"
- name: "Input 13"
- name: "Input 14"
- name: "Input 15"
- name: "Input 16"
- name: "Input 17"
- name: "Input 18"
- name: "Input 19"
- name: "Input 20"
- name: "Input 21"
- name: "Input 22"
- name: "Input 23"
- name: "Input 24"
- name: "Input 25"
- name: "Input 26"
- name: "Input 27"
- name: "Input 28"
- name: "Input 29"
- name: "Input 30"
- name: "Input 31"
- name: "Input 32"
in HA there are two Cards:
Outputs:
type: entities
entities:
- entity: switch.switch_1
- entity: switch.switch_2
- entity: switch.switch_3
- entity: switch.switch_4
- entity: switch.switch_5
- entity: switch.switch_6
- entity: switch.switch_7
- entity: switch.switch_8
- entity: switch.switch_9
- entity: switch.switch_10
- entity: switch.switch_11
- entity: switch.switch_12
- entity: switch.switch_13
- entity: switch.switch_14
- entity: switch.switch_15
- entity: switch.switch_16
- entity: switch.switch_17
- entity: switch.switch_18
- entity: switch.switch_19
- entity: switch.switch_20
- entity: switch.switch_21
- entity: switch.switch_22
- entity: switch.switch_23
- entity: switch.switch_24
- entity: switch.switch_25
- entity: switch.switch_26
- entity: switch.switch_27
- entity: switch.switch_28
- entity: switch.switch_29
- entity: switch.switch_30
- entity: switch.switch_31
- entity: switch.switch_32
state_color: true
title: ESP Shiftboard Outputs
and for Inputs:
type: entities
entities:
- entity: binary_sensor.input_1
- entity: binary_sensor.input_2
- entity: binary_sensor.input_3
- entity: binary_sensor.input_4
- entity: binary_sensor.input_5
- entity: binary_sensor.input_6
- entity: binary_sensor.input_7
- entity: binary_sensor.input_8
- entity: binary_sensor.input_9
- entity: binary_sensor.input_10
- entity: binary_sensor.input_11
- entity: binary_sensor.input_12
- entity: binary_sensor.input_13
- entity: binary_sensor.input_14
- entity: binary_sensor.input_15
- entity: binary_sensor.input_16
- entity: binary_sensor.input_17
- entity: binary_sensor.input_18
- entity: binary_sensor.input_19
- entity: binary_sensor.input_20
- entity: binary_sensor.input_21
- entity: binary_sensor.input_22
- entity: binary_sensor.input_23
- entity: binary_sensor.input_24
- entity: binary_sensor.input_25
- entity: binary_sensor.input_26
- entity: binary_sensor.input_27
- entity: binary_sensor.input_28
- entity: binary_sensor.input_29
- entity: binary_sensor.input_30
- entity: binary_sensor.input_31
- entity: binary_sensor.input_32
state_color: true
title: ESP Shiftboard Inputs
I hope this helps someone!
