78.3 not available in the HA app?
HI,
Did a fresh install of 78.3 hassos, but the iOS App won’t find it. Does this require an extra setting somewhere, I had the 75.3 version readily available in the app before.
thx
Read the release notes for 76, 77 and 78. There is a new auth system. You need to enable legacy password.
thx, but nothing on the App on 0.78: More auth, Switchmate, Yale Smart Alarm, OpenTherm - Home Assistant for as far as I can discover…
The app won’t even find the Hassos 78.3 instance, (not talking about being able to log in yet…)
wont the App use the new auth system?
Your search button might be broken :wink: I think this is the topic you’re looking for
A thats cool indeed, thanks! wait a few then, and use the new app soon…
but if i were to test the App would I need all the other http settings too? This is my current Http.yaml for 075.3
My 78.3 setup as nothing yet (is still strictly local). Would any of this ve still required, or also taken car of by the new Auth system?
api_password: !secret api_password
 # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: !secret base_url
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 3
#trusted_networks:
##  - 127.0.0.1
#  - 192.168.0.0/24
