.86 automation error
Everything has been working peachy. Upgraded to .86 and now get this message when I test configuration:
Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/ Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/ Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->1->minutes. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
All of my automations are individual files. I do not use the Automations editor. No errors were reported prior to this upgrade.
Any ideas on where to even start looking?
Did you read the breaking changes before upgrading?
Please use the formating
it look like some thing to do with the minutes I think
so have you a trigger that is a time
automation:
    platform: time
    at: '03:00:00'   # haves to be in a time format now NOT hour:
Think this was the OLD way of doing it
    platform: time
      hours: 3
      minutes: 00
      seconds: 00
Yep… with undivided attention. :slight_smile: Nothing in breaking changes applied to any of my hardware or configuration. (PI3B+, hass.io (current), Wink hub, various IP cameras, owntrack, Mosquitto MQTT resident).
You have to change time to time_pattern in your automation. I did that too.
Time triggers are split into two now.
Another noteworthy breaking change (sorry!), is that the automation time trigger has been split into two: time and time_pattern . If you had a time trigger containing the keys hours , minutes or seconds , update the platform from time to time_pattern .
I’m getting same error and I don’t have any time trigger and neither have the word “minutes” within the automations.yaml
This is my “hassio ha check” log
Error: INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /config
Failed config
  automation:
    - Invalid config for [automation]: [minutes] is an invalid option for [automation]. Check: automation->trigger->0->minutes. (See /config/configuration.yaml, line 435). Please check the docs at https://home-assistant.io/components/automation/
    - climate: [source /config/configuration.yaml:321]
        platform: netatmo
        relay: NetB3c
        thermostat: [source /config/configuration.yaml:324]
          - Termostato
      config: ?
      conversation: ?
      custom_updater: [source /config/configuration.yaml:91]
        card_urls: [source /config/configuration.yaml:96]
          - https://raw.githubusercontent.com/bramkragten/custom-ui/master/updater.json
          - https://raw.githubusercontent.com/kuuji/button-card/master/tracker.json
        track: [source /config/configuration.yaml:92]
          - components
          - cards
          - python_scripts
      customizer: [source /config/configuration.yaml:119]
        custom_ui: local
      device_tracker: [source /config/configuration.yaml:195]
        - platform: google_maps
          consider_home: 180
          interval_seconds: 300
          password: xxxxxxxx
          username: xxxxxx@xxxxx
        - platform: life360
          driving_speed: 18
          max_gps_accuracy: 200
          max_update_wait: [source /config/includes/device_tracker.yaml:18]
            minutes: 45
          password: xxxxxxxxx
          prefix: life360
          show_as_state: driving, moving, places
          username: xxxxx@xxxxxxx
        - platform: nmap_tracker
          consider_home: 180
          home_interval: 5
          hosts: 192.168.0.0/24
      frontend: [source /config/configuration.yaml:109]
        extra_html_url: [source /config/configuration.yaml:111]
          - /local/custom_ui/state-card-custom-ui.html
          - /local/custom_ui/custom-weather-card.html
        extra_html_url_es5: [source /config/configuration.yaml:114]
          - /local/custom_ui/state-card-custom-ui-es5.html
        javascript_version: latest
        themes: [source /config/configuration.yaml:109]
          dark_orange: [source /config/themes/dark_orange.yaml:1]
            dark-primary-color: #c66900
            label-badge-background-color: var(--sidebar-text_-_background)
            label-badge-blue: var(--light-primary-color)
            label-badge-green: var(--dark-primary-color)
            label-badge-grey: var(--paper-grey-500)
            label-badge-red: var(--primary-color)
            label-badge-text-color: var(--text-primary-color)
            label-badge-yellow: var(--text-primary-color)
            light-primary-color: #ffc947
            paper-card-background-color: #263137
            paper-card-header-color: var(--text-primary-color)
            paper-grey-200: var(--primary-background-color)
            paper-grey-50: var(--sidebar-text_-_background)
            paper-item-icon-active-color: var(--primary-color)
            paper-item-icon-color: var(--sidebar-text_-_background)
            paper-item-icon_-_color: var(--text-primary-color)
            paper-item-selected_-_background-color: var(--primary-color)
            paper-listbox-background-color: var(--sidebar-text_-_background)
            paper-progress-secondary-color: var(--sidebar-text_-_background)
            paper-slider-active-color: var(--primary-color)
            paper-slider-container-color: var(--sidebar-text_-_background)
            paper-slider-knob-color: var(--primary-color)
            paper-slider-knob-start-color: var(--primary-color)
            paper-slider-pin-color: var(--primary-color)
            paper-slider-secondary-color: var(--light-primary-color)
            paper-toggle-button-checked-bar-color: var(--dark-primary-color)
            paper-toggle-button-checked-button-color: var(--dark-primary-color)
            paper-toggle-button-checked-ink-color: var(--dark-primary-color)
            primary-background-color: #37464f
            primary-color: #ff9800
            primary-text-color: var(--text-primary-color)
            secondary-background-color: var(--primary-background-color)
            secondary-text-color: var(--primary-color)
            sidebar-text_-_background: #62717b
            table-row-alternative-background-color: var(--sidebar-text_-_background)
            table-row-background-color: var(--paper-card-background-color)
            text-primary-color: #ffffff
          dark_red: [source /config/themes/dark_red.yaml:2]
            disabled-text-color: #545454
            divider-color: rgba(255, 255, 255, 0.12)
            light-primary-color: #e06c6c
            paper-card-background-color: #1d1d1d
            paper-card-header-color: var(--paper-item-icon-color)
            paper-grey-200: #191919
            paper-grey-50: var(--primary-text-color)
            paper-item-icon-color: #d3d3d3
            paper-item-icon_-_color: var(--primary-text-color)
            paper-listbox-background-color: #202020
            paper-listbox-color: var(--primary-text-color)
            paper-toggle-button-checked-bar-color: var(--light-primary-color)
            paper-toggle-button-checked-button-color: var(--primary-color)
            paper-toggle-button-unchecked-bar-color: var(--primary-text-color)
            primary-background-color: #303030
            primary-color: #d32f2f
            primary-text-color: #cfcfcf
            secondary-background-color: #131313
          dark_theme: [source /config/themes/dark_theme.yaml:1]
            dark-primary-color: var(--red)
            dark_green: #017775
            dark_grey: #232326
            label-badge-background-color: var(--light_grey)
            label-badge-blue: var(--pink)
            label-badge-green: var(--pink)
            label-badge-grey: var(--pink)
            label-badge-red: var(--red)
            label-badge-text-color: var(--white)
            label-badge-yellow: var(--pink)
            light-primary-color: var(--red)
            light_green: #08a8a5
            light_grey: #344249
            paper-card-background-color: var(--light_grey)
            paper-card-header-color: var(--white)
            paper-grey-200: var(--dark_green)
            paper-grey-50: var(--light_green)
            paper-item-icon-active-color: var(--yellow)
            paper-item-icon-color: var(--dark_green)
            paper-item-icon_-_color: var(--pink)
            paper-item-selected_-_background-color: var(--light_green)
            paper-listbox-background-color: var(--light_grey)
            paper-progress-secondary-color: var(--pink)
            paper-slider-active-color: var(--yellow)
            paper-slider-container-color: var(--red)
            paper-slider-knob-color: var(--yellow)
            paper-slider-knob-start-color: var(--red)
            paper-slider-pin-color: var(--pink)
            paper-slider-secondary-color: var(--pink)
            paper-toggle-button-checked-bar-color: var(--yellow)
            paper-toggle-button-checked-button-color: var(--yellow)
            paper-toggle-button-checked-ink-color: var(--pink)
            pink: #ff0090
            primary-background-color: var(--dark_grey)
            primary-color: var(--light_green)
            primary-text-color: var(--white)
            red: #d10404
            secondary-background-color: var(--dark_grey)
            secondary-text-color: var(--white)
            sidebar-text_-_background: var(--pink)
            table-row-alternative-background-color: var(--dark_grey)
            table-row-background-color: var(--light_grey)
            text-primary-color: var(--pink)
            white: #f7f7f7
            yellow: #fffa0c
          midnight: [source /config/themes/midnight.yaml:2]
            accent-color: #E45E65
            dark-primary-color: var(--accent-color)
            disabled-text-color: #7F848E
            divider-color: rgba(0, 0, 0, .12)
            google-green-500: #39E949
            google-red-500: #E45E65
            label-badge-background-color: #2E333A
            label-badge-border-color: green
            label-badge-red: var(--accent-color)
            label-badge-text-color: var(--primary-text-color)
            light-primary-color: var(--accent-color)
            paper-card-background-color: #434954
            paper-card-header-color: var(--accent-color)
            paper-dialog-background-color: #434954
            paper-grey-200: #414A59
            paper-item-icon-active-color: #F9C536
            paper-item-icon-color: var(--primary-text-color)
            paper-item-icon_-_color: green
            paper-item-selected_-_background-color: #434954
            paper-listbox-background-color: #2E333A
            paper-listbox-color: var(--primary-color)
            paper-slider-active-color: var(--accent-color)
            paper-slider-container-color: linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat
            paper-slider-disabled-active-color: var(--disabled-text-color)
            paper-slider-disabled-secondary-color: var(--disabled-text-color)
            paper-slider-knob-color: var(--accent-color)
            paper-slider-knob-start-color: var(--accent-color)
            paper-slider-pin-color: var(--accent-color)
            paper-slider-secondary-color: var(--secondary-background-color)
            paper-tabs-selection-bar-color: green
            paper-toggle-button-checked-bar-color: var(--accent-color)
            paper-toggle-button-checked-button-color: var(--accent-color)
            paper-toggle-button-checked-ink-color: var(--accent-color)
            paper-toggle-button-unchecked-bar-color: var(--disabled-text-color)
            paper-toggle-button-unchecked-button-color: var(--disabled-text-color)
            paper-toggle-button-unchecked-ink-color: var(--disabled-text-color)
            primary-background-color: #383C45
            primary-color: #5294E2
            primary-text-color: #FFFFFF
            secondary-background-color: #383C45
            secondary-text-color: #5294E2
            table-row-alternative-background-color: #3E424B
            table-row-background-color: #353840
            text-primary-color: var(--primary-text-color)
          solarized: [source /config/themes/solarized.yaml:1]
            accent-color: #cb4b16
            disabled-text-color: #859900
            divider-color: #586e75
            google-blue: #268bd2
            google-green: #859900
            google-red: #dc322f
            google-yellow: #b58900
            label-badge-background-color: var(--secondary-background-color)
            paper-blue: #268bd2
            paper-card-background-color: #002b36
            paper-card-header-color: #cb4b16
            paper-green: #859900
            paper-grey-200: #586e75
            paper-grey-50: #b58900
            paper-item-icon-active-color: #dc322f
            paper-item-icon-color: #b58900
            paper-item-icon_-_color: #FF00FF
            paper-listbox-background-color: #002b36
            paper-listbox-color: #b58900
            paper-orange: #cb4b16
            paper-slider-active-color: #dc322f
            paper-slider-knob-color: #dc322f
            paper-slider-knob-start-color: #b58900
            paper-slider-pin-color: #FF00FF
            paper-slider-secondary-color: #dc322f
            paper-toggle-button-checked-bar-color: #cb4b16
            paper-toggle-button-checked-button-color: #dc322f
            paper-toggle-button-checked-ink-color: #dc322f
            paper-toggle-button-unchecked-bar-color: #b58900
            primary-background-color: #073642
            primary-color: #2aa198
            primary-text-color: #839496
            secondary-background-color: #073642
            secondary-text-color: #859900
            table-row-alternative-background-color: #073642
            table-row-background-color: #002b36
            text-primary-color: #839496
          teal_theme: [source /config/themes/teal_theme.yaml:1]
            disabled-text-color: rgba(255, 255, 255, 0.5)
            paper-card-background-color: #424242
            paper-card-header-color: #FFFFFF
            paper-grey-200: #616161
            paper-item-icon-color: #1DE9B6
            paper-listbox-background-color: #424242
            paper-listbox-color: #FFFFFF
            paper-slider-active-color: #1DE9B6
            paper-slider-knob-color: #1DE9B6
            paper-slider-knob-start-color: #1DE9B6
            paper-slider-pin-color: #1DE9B6
            paper-slider-secondary-color: #33F2D8
            paper-toggle-button-checked-bar-color: #1DE9B6
            paper-toggle-button-checked-button-color: #1DE9B6
            paper-toggle-button-checked-ink-color: #1DE9B6
            primary-color: #1DE9B6
            secondary-background-color: #303030
            secondary-text-color: rgba(255, 255, 255, 0.7)
      google: [source /config/configuration.yaml:365]
        client_id: xxxxxxx
        client_secret: xxxxxxxxx
        track_new_calendar: False
      google_assistant: [source /config/configuration.yaml:373]
        api_key: xxxxxxxxxx
        exposed_domains: [source /config/configuration.yaml:379]
          - climate
          - switch
          - light
        project_id: xxxxxxx
      group: ?
        ac_letto: ?
          control: hidden
          entities: ?
            - input_boolean.ac_letto_on_off
            - input_boolean.ac_letto_turbo
            - input_select.ac_letto_fan
            - input_select.ac_letto_mode
          icon: mdi:air-conditioner
          view: False
        ac_sala: ?
          control: hidden
          entities: ?
            - input_boolean.ac_sala_on_off
            - input_boolean.ac_sala_turbo
            - input_select.ac_sala_fan
            - input_select.ac_sala_mode
          view: False
        alarm: ?
          control: hidden
          entities: ?
            - alarm_control_panel.allarme_casa
          view: False
        availability: ?
          control: hidden
          entities: ?
            - device_tracker.broadlinklettofritzbox
          view: False
        batteries: ?
          control: hidden
          entities: ?
            - sensor.cubo_battery
            - sensor.motion_sensor_giu_battery
            - sensor.motion_sensor_su_battery
            - sensor.porta_ingresso_battery
            - sensor.finestra_cucina_battery
            - sensor.pressione_letto_battery
            - sensor.pressione_sala_battery
            - sensor.pulsante_battery
          view: False
        battery_alert: ?
          control: hidden
          entities: ?
            - input_number.battery_alert_threshold_min
            - input_number.battery_alert_threshold_max
            - automation.battery_notification
            - automation.battery_notification_clear
            - automation.battery_alert_slack
            - automation.battery_sensor_from_battery_level_attribute
            - automation.battery_sensor_from_battery_attribute
            - automation.battery_sensor_from_battery_numeric_attribute
        calendari: ?
          entities: ?
            - calendar.irrig
            - calendar.differenziata
          icon: mdi:calendar-clock
          view: False
        camloc: ?
          entities: ?
            - camera.vialetto
            - camera.patio
            - camera.porta
            - camera.giulia
            - camera.mamma
          icon: mdi:cctv
          name: Camera e Maps
          view: True
        cycle1_weather_settings: ?
          control: hidden
          entities: ?
            - input_boolean.cycle1_use_weather_adjustment
            - sensor.cycle1_zone1_duration_adjusted
            - sensor.cycle1_zone2_duration_adjusted
            - sensor.cycle1_zone3_duration_adjusted
            - sensor.cycle1_zone4_duration_adjusted
          icon: mdi:weather-partlycloudy
          name: Morning cycle weather settings
        cycle2_weather_settings: ?
          control: hidden
          entities: ?
            - input_boolean.cycle2_use_weather_adjustment
            - sensor.cycle2_zone1_duration_adjusted
            - sensor.cycle2_zone2_duration_adjusted
            - sensor.cycle2_zone3_duration_adjusted
            - sensor.cycle2_zone4_duration_adjusted
          name: Afternoon cycle weather settings
        daily_forecast: ?
          entities: ?
            - sensor.pws_weather_1d_metric
            - sensor.pws_weather_1n_metric
            - sensor.pws_weather_2d_metric
            - sensor.pws_weather_2n_metric
            - sensor.pws_weather_3d_metric
            - sensor.pws_weather_3n_metric
            - sensor.pws_weather_4d_metric
            - sensor.pws_weather_4n_metric
        default_view: ?
          entities: ?
            - group.alarm
            - group.temi
            - group.all_covers
            - group.all_automations
            - group.all_scripts
            - group.battery_alert
            - group.batteries
            - group.rpi
            - group.xiaomi
            - group.calendar
            - group.media_player
            - group.availability
            - sensor.ps4_today_time
            - sensor.ps4_today
            - group.yamaha_radio
            - group.gh_radio
            - group.gh_volume
            - group.gh_text
            - group.dove
            - group.calendari
            - group.pihole
            - group.fritz
            - group.zigbee_group
          icon: mdi:home
          view: True
        dove: ?
          entities: ?
            - input_boolean.dove_giulia
          name: Dove si trova
        energy: ?
          control: hidden
          entities: ?
            - sensor.owl_attuale
            - sensor.owl_totale
            - switch.presa_broadlink
            - sensor.rig_pow
          view: False
        fritz: ?
          entities: ?
            - sensor.fritz_is_connected
            - sensor.fritz_is_linked
            - sensor.fritz_external_ip
            - sensor.fritz_uptime
          icon: mdi:router-wireless
          name: Fritz Net Monitor
          view: False
        gh_radio: ?
          entities: ?
            - input_select.gh_radio_station
            - input_select.gh_source
            - script.gh_radio
          name: Google Home Radio
        gh_text: ?
          entities: ?
            - input_text.gh_testo
            - input_select.gh_source_tts
            - script.gh_tts
          name: Google Home Text
        gh_volume: ?
          entities: ?
            - input_number.google_home_mini_volume
            - input_number.google_home_volume
          name: Google Home Volume
        giardino: ?
          entities: ?
            - group.luci_giardino_auto
            - group.irrigazione
          view: True
        hum: ?
          control: hidden
          entities: ?
            - sensor.dark_sky_humidity
            - sensor.dark_sky_precip_intensity
            - sensor.dark_sky_precip_probability
            - sensor.dark_sky_wind_speed
            - sensor.dark_sky_wind_bearing
            - sensor.dark_sky_summary
            - sensor.dark_sky_cloud_coverage
          name: Umidità, pressione e pioggia
          view: False
        irrigation: ?
          entities: ?
            - group.zone_1
            - group.zone_2
            - group.zone_3
            - group.zone_4
            - group.reset_zones
          icon: mdi:water-pump
          view: True
        irrigation_cycle1: ?
          control: hidden
          entities: ?
            - input_boolean.cycle1_enable
            - sensor.cycle1_next_run_time
            - input_boolean.cycle1_manual_run
            - input_select.cycle1_schedule_time
            - input_select.cycle1_watering_days
            - input_number.cycle1_zone1_duration
            - input_number.cycle1_zone2_duration
            - input_number.cycle1_zone3_duration
            - input_number.cycle1_zone4_duration
        irrigation_cycle1_status: ?
          control: hidden
          entities: ?
            - sensor.cycle1_running
            - sensor.cycle1_zone_being_watered
            - timer.cycle1_zone_duration
            - group.cycle1_weather_settings
          name: Morning Cycle Status
        irrigation_cycle2: ?
          control: hidden
          entities: ?
            - input_boolean.cycle2_enable
            - sensor.cycle2_next_run_time
            - input_boolean.cycle2_manual_run
            - input_select.cycle2_schedule_time
            - input_select.cycle2_watering_days
            - input_number.cycle2_zone1_duration
            - input_number.cycle2_zone2_duration
            - input_number.cycle2_zone3_duration
            - input_number.cycle2_zone4_duration
        irrigation_cycle2_status: ?
          control: hidden
          entities: ?
            - sensor.cycle2_running
            - sensor.cycle2_zone_being_watered
            - timer.cycle2_zone_duration
            - group.cycle2_weather_settings
          name: Afternoon Cycle Status
        irrigation_information: ?
          control: hidden
          entities: ?
            - group.irrigation_weather_information
            - input_number.temperature_baseline
            - input_number.rainfall_threshold
            - sensor.last_irrigated_time
            - sensor.zone1_time_today
            - sensor.zone2_time_today
            - sensor.zone3_time_today
            - sensor.zone4_time_today
          name: Irrigation Information
        irrigation_valves: ?
          entities: ?
            - switch.zone1_valve
            - switch.zone2_valve
            - switch.zone3_valve
            - switch.zone4_valve
        irrigation_weather_information: ?
          entities: ?
            - sensor.temp_high_2days
            - sensor.temp_high_5days
            - sensor.temp_minus0
            - sensor.temp_minus1
            - sensor.temp_minus2
            - sensor.temp_minus3
            - sensor.temp_minus4
            - sensor.rain_3days_ratio
            - sensor.rain_minus0
            - sensor.rain_minus1
            - sensor.rain_minus2
            - sensor.rain_minus3
          name: Weather Information History
        irrigazione: ?
          control: hidden
          entities: ?
            - switch.irrig1
            - switch.irrig2
            - switch.irrig3
            - switch.irrig4
            - input_boolean.all_irrigator
          view: False
and this is my automations.yaml
###### Tutti gli irrigatori ################
- id: tutti_irrigatori_on
  alias: Accendi utti gli irrigatori
    platform: state
    entity_id: input_boolean.all_irrigator
    to: 'on'
  - service: script.turn_on
      entity_id: script.turn_on_all_irrigation
- id: tutti_irrigatori_off
  alias: Accendi tutti gli irrigatori
    platform: state
    to: 'off'
      entity_id: script.turn_off_irrigation
###### AC Letto On ################
- id: ac_letto_on
  alias: Accendi AC Letto
    platform: state
    entity_id: input_boolean.ac_letto_on_off
    to: 'on'
  - service: switch.turn_off
      entity_id: switch.ac_sala
  - delay: '00:00:02'
  - service: switch.turn_on
      entity_id: switch.ac_letto
  - data_template:
      message: "Accendo condizionatore della camera da letto."
    service: notify.telegram
###### Volume Google Home #################
- id: google_home_mini_adjust_volume
  alias: "Google Home Mini - Adjust Volume"
      platform: state
      entity_id: input_number.google_home_mini_volume
    - service: media_player.volume_set
      data_template:
        entity_id: media_player.salotto_2
        volume_level: '{{ states.input_number.google_home_mini_volume.state }}'
- id: google_home_adjust_volume
  alias: "Google Home - Adjust Volume"
      platform: state
      entity_id: input_number.google_home_volume
      data_template:
        entity_id: media_player.soggiorno
        volume_level: '{{ states.input_number.google_home_volume.state }}'
##### HASS Themes change #########
- id: hass_theme
  alias: hass_theme
  initial_state: 'on'
    - platform: state
      entity_id: input_select.hass_theme
    - service: frontend.set_theme
      data_template:
        name: "{{ states.input_select.hass_theme.state }}"
############## SPOTIFY #################
- id: zigbee_log_level
  alias: Zigbee2mqtt Log Level
  initial_state: 'on'
    - platform: state
      entity_id: input_select.zigbee2mqtt_log_level
      to: debug
    - platform: state
      to: warn
    - platform: state
      to: error
    - platform: state
      to: info
    - service: mqtt.publish
        payload_template: '{{ states(''input_select.zigbee2mqtt_log_level'') }}'
        topic: zigbee2mqtt/bridge/config/log_level
- id: enable_zigbee_join
  alias: Enable Zigbee joining
  hide_entity: true
    platform: state
    entity_id: input_boolean.zigbee_permit_join
    to: 'on'
      topic: zigbee2mqtt/bridge/config/permit_join
      payload: 'true'
  - service: timer.start
      entity_id: timer.zigbee_permit_join
- id: disable_zigbee_join
  alias: Disable Zigbee joining
  - entity_id: input_boolean.zigbee_permit_join
    platform: state
    to: 'off'
  - data:
      payload: 'false'
  - data:
    service: timer.cancel
  hide_entity: true
- id: disable_zigbee_join_timer
  alias: Disable Zigbee joining by timer
  hide_entity: true
  - platform: event
    event_type: timer.finished
    event_data:
      payload: 'false'
  - service: input_boolean.turn_off
############## Update stato Shellies #################
- alias: 'Shelly Status Info at Start'
    - platform: homeassistant
      event: start
        topic: shellies/command
        payload: announce
In your device tracker file can you comment out this entire platform? I wonder if the config check has gone bonkers and applies the rules outside of the automations.yaml.
time_pattern change from time seemed to have no effect. Here’s one of my more basic automations that now seems to puke:
- alias: 'Reboot Home Assistant Server'
  initial_state: true
  - at: 02:00:00
    platform: time
  condition:
  - condition: time
    weekday:
    - sun
    - thu
  - service: hassio.host_reboot
Don’t you need quotes around times? YAML uses : so you need to encase that
Great thought… but no change. Tried both single and double quotes.
what does line
[source /config/configuration.yaml:321] SAY
I tried to remove Life360 from device_tracker.yaml, but same error
I’m seeing more and more people having the same error, even people with no automation at all
Okay, now it’s getting really weird. I have no automations in the automations editor/automations.yaml. I have commented out the line:
automation old: !include_dir_merge_list automations
I have NO automations anywhere yet when I run a configuration check I get:
(note: I even removed the entire automations folder.)
I found the solution thank to @Klagio in the main 0.86 thread
The automations with minutes were in some .yaml files in the config/packages folder.
I just modified from platform: time to platform: time_pattern (only the one that contains hours, minutes and seconds) and all is working now.
Geez! That was it! I also just found one of those in a package I had installed a year ago and had been running flawlessly.
Yet more ammunition to my argument that Packages are bad software protocol and just a bad idea in general.
THANK YOU EVERYONE for your guidance and support!
You have to admit that, given the rapid evolution of Home Assistant, anything that runs flawlessly for a year and is unaffected by dozens of updates, ain’t all that bad! :wink:
FWIW, you can use this Linux command to recursively search through all files for a given string. Change to your config directory and run this to find any line containing : time
grep -rni ": time"
If you have got battery_alert package installed, you will need to update the file to the latest version 1.2.1
This is indeed a breaking change in 0.86.1. Actually it not only impacting the time trigger, but in my case also automation based on state or numeric trigger where I use form x hours/minuites/seconds.
Ex:
  • alias: “ALERT DISK SPACE LOW”
    hide_entity: false
    initial_state: ‘on’
    • platform: numeric_state
      entity_id: sensor.disk_use_percent
      above: 50
      for:
      hours: 1
      minutes: 30
Does it get fixed if you change it to:
for: '01:30:00'
Because if that fixes it then the release notes should be updated to indicate that the elimination of hours, minutes, and seconds isn’t limited to just the time platform.
Let us know the results.
