Checked my config and then hit install in configuration frame. Fifteen minutes later, whole device was dead (ssh was declined).
Rebooted. Found 88.2 running. Used ssh to hassio. Hassio ha info indicated 89 available, but 88.2 installed. Did hassio ha stop, then hassio ha update. 20 minutes later had to pull power cord and reinsert to get device to stop endless solid erd/green lights. Found 88.2 still installed and willing to run.
This has happened to me over the past with various releases. Check you have enough space on you SD card. Quick fix delete all log files and HA.DB ( after stopping HA first). Reboot pi and try update again
Same issue for me. Tried to delete the database, and to force installation via SSH but no luck. 0.89 still won’t update.
From the log only this two rows:
WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
I’m running HASSos updated day before yesterday to 2.10… maybe this could be the problem?
HASSos is running in a VM, VHD 16GB and RAM 4GB, so I guess it’s impossbile I’m out of space.
Neither of those refer to disk space. If you used the default HassOS image of 6 GB you could very well be out of disk space. My very basic HassOs configuration is over 5 GB.
From the VM console login prompt type:
root
login
df -hl | more
Look for any mount points showing 95% user or higher.
19-03-08 13:38:23 INFO (SyncWorker_12) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.89.0
19-03-08 13:48:25 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-03-08 13:48:25 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-03-08 13:48:25 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.88.2
No mount point over 50% for me… @anon34565116: I don’t understand why you said “Neither of those refer to disk space”; Disk size is in fact “disk space” as the output before has shown
I’ve the same issue as @freddy_yu, no problem with the precedent update, only with 0.89 .
I had small issuue yesteday and could not figure out why automatic rollback was happening every time I was attempting to upgrade 0.88.2 -> 0.89.1.
After going through list of breaking changes in release notes and few experiments I discovered that in my case problem was caused by trusted_networks related changes.
In configuration.yaml I moved trusted_networks block from http: where it was for very long time to auth_providers: like so:
